Old 11-15-2023, 02:40 PM
Originally Posted by ZeGermanHam View Post
It has a very faint u-joint vibration at ~65mph, so I'll adjust the pinion angle soon which should take care of that. I only eyeballed it when I put the rear in. Otherwise, the car performed flawlessly.
Can you tell me a little about that process? How you check it, change it and verify it?
I swapped rear ends last year and have the same symptom at the same speed.
EDIT- Scratch that... I see that you used adjustable aftermarket suspension parts at the rear. Mine is a factory setup so I suppose my vibration is from another issue.
  #442
Old 11-15-2023, 07:25 PM
ZeGermanHam's Avatar
Yes, I did use adjustable upper links for my differential that allow me to change the pinion angle.
I'd still recommend verifying the pinion angle in your car even if you have stock, non-adjustable upper links. To check it, you'll want to elevate the car on level ground and have the full weight of the car on the axle or wheels. For people without a 4-post lift to drive onto, that would mean supporting the car by placing jack stands under the axle tubes so the rear suspension is weighted. From there, you will want to disconnect the driveshaft from the rear and use an angle finder (can be a free phone app) to determine how many degrees from zero you are at. My understanding is that the reading should be in the ballpark of 3-degree (not less), and equal and opposite to the angle of the output flange of the transmission.
So if the transmission is angled downward 3 degrees, the differential should be angled upward 3 degrees, give or take.
I'm not an expert on this, so someone please correct me if I'm wrong.
If you find that your pinion angle is not where it needs to be, you might need to buy adjustable upper links to get there.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
  #443
Old 11-16-2023, 10:32 AM
Thanks. I have a couple of things to do underneath it soon and I could take a look. I did replace rear control arm bushings and boxed them while I was doing the rear end swap. I may have possibly wound up a few degrees off.
