Trunk Torsion Rods
I searched and didn't find what I was looking for, so figured I'd ask...
Trunk/deck lid rods for wing cars, were they different than non-wing cars, or just on a different adjustment hole? Have a lazy deck lid I'm trying to resolve, any suggestions would be helpful and appreciated. .
Different adjustment hole.
So is it the end adjustment hole, closest to the back seat, or closest to the rear of the car?
I remember at one point there was a tool for doing the adjustment, any tips there? .
When I got my 71 Judge, that was one of the first things I checked. The size of the trunk rods as compared to the non-winged GTO's. They were the same size. Like Ram4king said the "adjustment holes" will allow you to change the spring tension.
It's hard to explain without a picture but you want to move it one notch higher.
Thank you gentlemen, that's helpful. Any tips on moving the rods?
When I looked at mine they were in different holes on different sides. I'll have to go look again, but as I remember one side is in the center hole and the other side is in either the hole closes to the back seat or the trunk, not sure which. I've always thought this was wrong....most likely done when the car was restored 20 years ago. Don't Think it left the factory that way. Any consensus on which holes are correct?
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
I use a long socket and long extension as the tool to move them, a socket that just fits snug. They seem to have been adjusted differently not just for the Judge but also for the presence of factory (not dealer) installed remote trunk release. Power trunk cars are set lower, I guess so the trunk wouldn't fly open, the lid only pops up an inch or two and then if raised by hand they stay open all the way. Non power trunk cars will pop open all the way if you let go of the key. I've seen this enough over hundreds of boneyard cars in the 70's and 80's to know this was not a co-incidence.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
For example two of my 69's had a factory trunk release and the bars are bottom position on the left and middle on the right, my third 69 which came without a trunk release is middle on the left and top on the right (none are Judges).
Ah, a socket, yeah, makes sense. Thanks! Guess I can try different positions and use what seems to work for me.
Excellent, thank you all! .
Thanks.
Hm. I have a fisher body manual, should dig that up and see.
I don't recall anything in the assembly manual about which hole to use, but I think the Fisher manual explains how to adjust the setting afterwards.
In my 11-1-69 Masterparts catalog the listing are:
69-70 ht wo/air foil lh 8733944 rh 7754538 69 ht w/air foil lh 8790660 rh 8790659 69-70 conv wo/air foil lh 7765580 rh 7765581 69 conv w/air foil lh 8790132 rh 8790133 No listing for -70 w/air foil...
`70 GTO, 370 hp, 3:90, TH400. |
Makes sense since the adjustment of the bars might not have been enough to reliably correct for the weight of the wing. The absence of the 70 Judge is probably because the MPC you refer to was not complete in terms of 70 specific parts.
Strange...
one of mine snapped a while back and I sourced a set from a silver 70 GTO that a fellow was parting at the co-vention...they are the same as my Judge originals. Color coded on the ends pink and the other was orange with alot of silver over spray on them .
One of mine snapped too, at the body shop, they were trying to get it to the next hole. So figured I'd need a pair.
Looked at Parts Place, they have them, but list them in either 44 or 46". Seems the 46" worked for me, but the body guy didn't get it to the next notch. Maybe he didn't want to break another! .
Coming back around to this, looks like my current rods are in the last holes, and it's not lifting or holding the lid with the wing up.
Anyone have part numbers for the 70 judge? I suspect I need a thick one, or for both? .
there is no Judge specific rod..... they are just positioned differently
