Muffler recommendations
Just had a new exhaust installed on the firebird and don't like the sound, too loud and it just drones. I wanted something a little louder than stock but now I want something quiet. Any recommendations? Its a 69 firebird with a 350 manual trans and stock exhaust manifolds.
Dynomax Super Turbos - No drone, very efficient and would fit your desire for a "little louder than stock".
The Following User Says Thank You to The Champ For This Useful Post: | ||
I agree with above answer. Just wondered what’s on it now?
Turbo mufflers were installed, not sure of the make.
As far as the Dynomax recommendation, what you want for quiet is the 17749 long case super turbos. I have regular 14" ones on my Catalina now and will be switching up soon after riding in a friend's 64 Catalina with the long case ones. He has a Len Williams 455, 041 cam, Rhoads lifters and long tubes. Exhaust is 3" with H pipe to the mufflers and 2.5" tailpipes out the back. The car is damn near silent inside even cruising at 3k rpm.
Thanks for all the replies, it helps a lot.
I have Dynomax Super Turbos that I am planning to put on my car because I want it to not be loud, but I'm surprised to hear folks saying they are efficient and don't hurt power too much. There have been episodes of Engine Masters which show the turbo style mufflers were significantly restrictive and down on power compared to chambered style mufflers. Agree that if you just want something for a cruiser that is a little louder than stock, turbo style mufflers are a great option. But I'd stop short of calling them efficient.
Also FWIW, the 2.5" Dynomax Super Turbo mufflers actually neck down to 2.25" inside, but the Summit brand turbo mufflers are a true 2.5" all the way through.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 05-05-2022 at 02:49 PM. |
-The straight-through mufflers with packing (flow piping doesn't do 180* turn) flow the best.
-Turbo mufflers where the exhaust has to 180* and back again, are less efficient. -Chambered mufflers vary a lot by manufacturer design. They rarely, if ever work as well as straight through. But comparing to turbo-style some are occasionally marginally better, many often worse.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
https://www.pontiacstreetperformance...p/exhaust.html |
The chambered flowmasters were all on the low end of performance. Supertrapps are kind of their own animal since they're essentially a tunable tailpipe. Not sure what the AP Xlerator or discontined CVX muffler designs were like inside.
I have a 78 T/A with a complete RAIII and RAIII manifolds. In the 80's my car would blow exhaust manifold gaskets constantly. I tried every kind of gasket to no avail. I always thought I needed to bring the manifolds to a machine shop to have them cut. I came across a set of Flow Master two chamber mufflers and put them on. I never blew another manifold gasket again, its been 40 years. Point is, Turbo mufflers not as free flowing as one would think.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Love my Borlas, straight through, but not loud. Million mile warranty too.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes pause pause F ire B irds 🇮🇱 |
With a Torque Tech mandrel bent, with band clamps that didn’t bent the pipes, I didn’t like how Pipes puts their Logo on stuff, you can’t remove it easily, and they were very thin tips at that. The ones I saw at a show were out of round they were so thin. I had a custom 2.5” set made.
I put 17749s on my brother's 1970 LeMans vert with a 530 Hp motor and 4 speed. Was going to go with the Dynomax Ultraflows, but it would have been too loud with the top down. The 17749s are perfect sound wise and no drone. I used a Pypes 2.5" mandrel bent system and 2" headers.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
amcmike
I run the 17749's on the GTO. Why look at anything less efficient and/or more expensive - regardless of brand name? Besides, it's what the OP poster is looking for. |
Then you said the Hands data contradicted my general statements, and I pointed out how they actually supported my statements. The brand names I used in my follow up post was simply to identify and relate back to the performance of the test, to show my original statement was valid. I never implied one brand was better than another. Nor did I say there's anything wrong with Dynomax or that turbos don't flow well. I didn't realize we weren't allowed to correct information, support our statements, nor add technical content beyond an OP's original question.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman Last edited by amcmike; 05-06-2022 at 08:37 PM. |
Maybe it's an optical illusion, but the passenger side off the exhaust manifold on top looks crushed or kinked.
I see the area your looking at, I think. It looks much like the driver side which you can see better. It's where the pipe is clamped and stretched making that tight bend. Yes it is mis-shapped a little. Probably lose 1/4" effective diameter. Not allot of options there. It is not crushed. If you or someone else can turn the pics, that would be greatly appreciated. I just don't know how to do it on this forum.
The 20” case 17749 is my go to for both of my ‘64 A-body Pontiacs, however they’re simply too long to fit in the recess under the back seat floor pan of an F-body.
I used a pair of the 14” case 17734 mufflers on my ‘76 T/A and they were a good fit, I suspect your ‘69 has similar space constraints. They were a little more aggressive sounding than the larger 17749 mufflers but still good for something you’re driving a lot. Smaller 2-1/4” tail pipes would tone them down a bit without sacrificing performance. Ground clearance with dual exhaust and these fairly large mufflers isn’t that great. If a low profile muffler with good sound quality is available I’d be looking into those. There just isn’t much room under the floors of an F-body.
I think one of the tests I saw the TV guys do they were stunned at how well the Super Turbos actually flowed. Not sure they had done lot of studying to see how the flow directors work but likely as not, they did not have time nor desire to advertise one brand over another. They were learning that the front pipe diameter is more important than muffler style, assuming the mufflers are close in flow capability.
Tom Hand |
