Old 01-16-2020, 01:59 AM
pgp66's Avatar
pgp66 pgp66 is offline
Default Flywheel?
Hi all.
Can someone please confirm with me that this flywheel is off a Pontiac V8 first up, so it will fit a 400/455 standard crank? Just want to confirm before I buy it. It is 13 1/4 diameter and 11 5/8 bolt hole centers. Number on the back is 9779233. See the pics.
Putting in in front of a 26 spline Muncie M20, so can you also confirm will this clutch fit that flywheel?
https://www.summitracing.com/int/parts/mcl-75225
Thanks in advance.
Paul
ID:	528916   Click image for larger version
ID:	528917   Click image for larger version
--> 1966 Pontiac Le Mans Convertible, Martinique Bronze, black top, Parchment interior, alloy Rallye 2's, M/T Sportsman ST's 235f/255r with redlines, 464 (455 .040 over), Performer RPM 87cc round port heads, Butler roller cam, Edelbrock Pro-Flo 4, Ram Air 2.5" manifolds, 67 GTO Ram Air pan, 2.5" Magnaflow, Muncie M22, 3.55 Eaton Posi. <--
Old 01-16-2020, 05:17 AM
Scott Thelander's Avatar
its a pontiac part number
its dated june 15 1970
it fits the 10.5 " clutch
I dont see a bevel on the edge ...
and it looks like it needs another surfacing
It might be gettin a little thin ... and unsafe...
Old 01-16-2020, 03:03 PM
pgp66's Avatar
Thanks Scott. Agreed it will need a resurface, but where do I find the dimensions info so I know if its already too thin?
And thanks for the other info so I know it is the one I want.
Old 01-17-2020, 02:53 PM
Just buy a new one, it's not worth the risk using an old, unknown source for a flywheel.
The Pioneer, PRW, and Hayes SFI ones are fine. I've always used the Hayes ones, 30lbs for everything except 326/350s, then the 15lbs is fine.
