Old 01-17-2020, 02:48 PM
HWYSTR455's Avatar
You can call machine shops and ask if they have any extra boxes, or just buy specific boxes.
Old 01-18-2020, 09:30 AM
JSPONT's Avatar
JSPONT JSPONT is offline
A guy on another forum used the expanding household spray foam inside the A and B pillars and rockers on a classic Packard. The stuff turned out to be acidic, and caused the entire body to rust out. Car was destroyed. Do your research before you spray.
Built a Packard and was to cheep to buy automotive foam, LOL. Funny part is rather than foam he count have got a 360 spray nozzle that comes with a long hose and used bees wax to coat the inside, or even an etch primer.
Old 01-18-2020, 10:35 AM
LATECH's Avatar
LATECH LATECH is offline
Originally Posted by Will View Post
I tried this when shipping a turbo and found that commonly available expanding foam in a can won't dry without contact with air.
you have to get a special kind (anaerobic) and it's quite a bit more expensive, otherwise the foam dries unevenly and leaves pockets of liquid. That was a mess.
Never had that problem. My cheap blowfoam dried just fine. Maybe the foam you bought was defective. I have shipped numerous Items this way and NEVER had that type of trouble.
Old 01-18-2020, 10:38 AM
LATECH's Avatar
Originally Posted by daduck View Post
that is how I do it. Bman knows the routine.
Lookin good.
Old 01-18-2020, 10:40 AM
LATECH's Avatar
https://en.wikipedia.org/wiki/Spray_foam
Old 01-18-2020, 10:43 AM
LATECH's Avatar
Sounds more like to me that it trapped moisture and caused the issue
The foam is non toxic once dry.It would make sense that it would be chemically nuetral at that point. IDK
Old 01-18-2020, 10:44 AM
LATECH's Avatar
BTW I use the "Great stuff" brand which is a one step closed cell foam.
Old 01-18-2020, 10:46 AM
LATECH's Avatar
http://msdssearch.dow.com/PublishedL...romPage=GetDoc
Check pragraph 9 in the data sheet
Old 01-18-2020, 10:47 AM
LATECH's Avatar
Acid would be toxic.
Old 01-18-2020, 10:48 AM
LATECH's Avatar
https://www.familyhandyman.com/diy-a...low-your-mind/
