Old 11-26-2018, 03:09 PM
Chris65LeMans's Avatar
Default Has anyone used CVF racing serpentine systems? - brought on by an unusual issue.
I've been wanting to upgrade to a serpentine pully system for a while, but would rather avoid spending $3,000 on a March kit that I think is too "shiny" anyways.
Someone on the forum here mentioned CVFRacing, and they have a nice kit that doesn't require a new power steering pump or alternator for under $600. I figured I'd see if anyone has experience/tips.
I'll probably give it a try in a few days. As with many things, my upgrades come after things break. I took a nice 120 mile cruise in the Pontiac, and noticed that the lights were getting dim on the way home. Under the hood, I found that the plentiful Pontiac torque had sheared one of the studs that held the alternator in place clean off. We rode the 30+ miles back home on a tow truck.
Old 11-26-2018, 05:14 PM
JSPONT's Avatar
JSPONT JSPONT is offline
I have had there set up for a while. There are pro and cons to everything, but for the money I was happy. You might have to shim some things to get the belt line perfect. I do not have power steering or a/c either.
Old 11-26-2018, 05:16 PM
hdinch's Avatar
hdinch hdinch is offline
I have that kit on my 73 bird. When I ran #12 heads and needed something that would not take the typical alternator location as the heads did not have that bolt hole. Anyway now run KRE heads and the system works great on both. I bought the full kit with pulleys etc. I did a good write up on my build thread at Firebirdnation. The vendor was great to work with and helped me out when the smaller kit did not initially work. He sent me at no cost the upgraded kit. Thats when I documented it and gave him props.
1973 Firebird Formula
1969 Firebird Convertible
Old 11-26-2018, 07:05 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Aren't you missing the steel bracket that supports the front of the alternator? With no support on the front side, the load from the belt will be putting side force on that bolt causing it to break like it did.
Unless you really want serpentine, I think all you need to do is get the correct front bracket and a new bolt.
Old 11-26-2018, 07:24 PM
I have the front bracket - When I took this picture, it was loosened and angled up and out of the way so I could remove the alternator. The tow truck placed the car in my driveway - I had to get the belts out of the way so I could fire it up and park in the garage. Everything stayed aligned while I was driving, but I couldn't get it back in place after I started loosening things during an attempted parking lot repair.
Old 11-26-2018, 07:44 PM
I would repair the bolt and put it back like it was. I think these belt systems are way over priced, and I dont like any without a Auto Tensioner.
Bill Nye.
Old 11-26-2018, 08:03 PM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
I run their full serpentine kit including A/C, on my 69 goat, never had any issues installing it, went on perfectly, everything lined up, and its been on for 2 years now trouble free.
I also run my car hard on week-ends, car often sees 5000rpm in third, I cannot fault their setup at all!
Your car must be very fast !
Because you were haulin ass when I passed you in my GTO.
Old 11-26-2018, 08:40 PM
I see that you have hydro boost also. What ps pump are you running? I’m not sure my current one will work with this setup. (No stud in the lower right on the back - I have a hose there.)
Do you think the lack of an auto-tensioner is a big deal?
Thanks.
Old 11-26-2018, 09:05 PM
Ozzmann's Avatar
Thanks.
Hydro boost was without doubt the best upgrade ever! I already had the correct pump on the car, which was just a original pump but have since replaced it with a shiny one I then added the extra outlet so I could get rid of the tee piece, but it did work fine with the tee piece.
I don't think the auto tensioner is missed at all, the turn buckles give me all the tension I need, and like I said, I run my engine at high rpm at 120mph and never had my belt slip.
Old 11-26-2018, 09:26 PM
hdinch's Avatar
Also running the Hydroboost--such a great improvement. This is what the CVS system look like, could not find a closer pic.
Old 11-26-2018, 10:18 PM
Yeah, I’ve had hydroboost for four years now, and love it.
I’ll call them tomorrow to make sure my ps pump will work with their kit. Their site seems to say that only one kind of pump will work - but that doesn’t seem to be the case if it works for you guys. (my pump has 3 hoses coming out of it.)
Old 11-26-2018, 10:26 PM
Ozzmann's Avatar
I do believe GM used two different types of p/s pumps, and remember CVF only worked with one, which I was lucky enough to already have. If you need a new one, they sell them as well.
Old 11-27-2018, 10:43 AM
64speed's Avatar
64speed 64speed is offline
I bought there V belt setup because I got a really good deal on a manufacturer coupon my nephew got for buying a ford setup. It looks like quality pieces and it recommended the power steering pump I didnt have so I got one from them. I cant remember who it was but someone on here said their power steering pump was awesome so I bought one.
Old 11-27-2018, 02:39 PM
RH68 RH68 is offline
I bought the CVF conversion a few months ago. Overall happy with it. Biggest issue I had was that the recommended belt was too short. I had to get one that was about 1 inch longer from Napa.
Also I bought their ps pump. It is a nice looking unit. But, the kit doesn't even mount using the lower right stud they mention so my original pump would have worked too.
Old 11-27-2018, 02:40 PM
From the photos, their pump only has 1 tube coming out. MIne has two; plus an additional hose screwed into the back. I had someone set this up for me, so I'm not really sure how it all works. Hopefully they can be of some help. I left them a message an hour or so ago, and am waiting to hear back.
Old 11-27-2018, 03:25 PM
azbirds's Avatar
azbirds azbirds is offline
I looked closely at the picture with you pointing at the bolt. The lower nuts appear to be on and tight. There is a lower bracket missing that goes in front of the p/s bracket that has three holes in it and it supports the front of the broken bolt. In the picture it looks like some rubbing took place due to the bolt flexing.
When people tell me they HAD to sell their car when they started a family, I show them the three car seats in the back of my 69Trans-Am..............and we didn't even use car seats back then!!
Old 11-27-2018, 05:54 PM
I looked at your photo, and the rear bracket is different than mine. (Firebird/A body difference?)
At any rate, I went ahead and ordered the kit. Although the CVF site says that there MUST be a mounting stud in the rear right of the PS pump, the rear bracket is adjustable, and - it turns out - that spot isn't even ideal. Their customer service says that there are other rear brackets available if the first one doesn't work.
I'll let you all know how it goes, and will post pics. Thanks, all, for your help!
Old 11-27-2018, 08:22 PM
vidguy's Avatar
vidguy vidguy is offline
I don't know if it will help at this point but I have a CVF PS Pump for sale. it wan't part of the Serpentine system but is brand new.
https://photos.google.com/share/AF1Q...M1MjA4R3N5UkV3
Here is my thread/post
http://forums.maxperformanceinc.com/...5&postcount=19
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 11-28-2018, 09:26 AM
HWYSTR455's Avatar
Exactly, and good catch.
Yes, the bracket/strap that goes on the front of the alt is missing, and all those series brackets use that strap. You should not have just a bolt thru the alt going directly into the rear bracket, there's no support on the front of the alt and it's going to stress that. That's what made the bolt snap.
Old 11-28-2018, 09:32 AM
HWYSTR455's Avatar
There's only one bracket that I'm aware of for setups with PS on pre-70 setups.
Here's a pic of the bracket setup, and the factory exploded diagram.
ID:	498905   Click image for larger version
