Old 04-09-2023, 08:01 PM
I think you need to leave the amount of Vacuum Advance out of your total timing equation. Initial +Centrifugal = 30-32-34. I think most GM cars end up with approx 50 BTDC total at cruise.
Bill Nye.
  #342
Old 04-09-2023, 08:15 PM
Verdoro 68's Avatar
That’s right. I have it set to 15 degrees initial + 17 mechanical for a total of 32. I’d like to experiment with up to 36, it that would push my initial up to 18-19. Maybe that’s ok if it starts fine? I haven’t really been worried about the vacuum advance other than to make sure it’s working.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
  #343
Old 05-10-2023, 12:35 AM
Verdoro 68's Avatar
I haven't had as much road time as I would have liked in the car since I got it running. I sent my distributor off to a couple weeks ago and it appears to be MIA somewhere between TN and CA right now. Hoping it gets here for the show at my son's school next week.
In the mean time, I received a new 9.5" TSP converter that Cliff specced for me. The old 13" Continental wasn't enough and while the mystery 12" I got from the trans builder was better, there was room for improvement. According to the paperwork he set this one up for 3k stall. Can't wait to try it out.
Between the distributor tweaks and the new converter this thing should be pretty well dialed in. We'll see if the nodular 8.2 holds up.
I did get the A/C hoses crimped up and a new drier installed. Here's a couple pics from a cruise in a few weeks ago looking all fresh.
ID:	612378   Click image for larger version
ID:	612379   Click image for larger version
Ken
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
  #344
Old 05-10-2023, 01:25 AM
scott70's Avatar
scott70 scott70 is offline
Is it weird for me to like the center exhaust ports on a round port head? Is that strange?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
  #345
Old 05-10-2023, 07:17 AM
SD455DJ SD455DJ is online now
Heck no! They always look awesome to me too! It's amazing how straight cast iron can change perceptions!
Dennis
  #346
Old 05-10-2023, 07:25 AM
Ken, That convertor should make a world of difference for you. The GTO is a true work of art! I love it! You may need a good 12-bolt rear in the future with all that power and a 4-speed. All it took was one rolling full throttle blast in my 462 LeMans with the M-20 4-speed to take out the original gray iron 8.2 10 bolt (with 3.23 Safe-T-Track). We were fortunate that we had a McKinnon 3.07 12 bolt rear from a '70 GP under the bench to rebuild. The gears were toast, so we replaced them with a new 3.08 Yukon gears, posi, and axles. Now the weak link is the M-20, so taking it easy on the old gal.
Dennis
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
  #347
Old 05-10-2023, 12:09 PM
Verdoro 68's Avatar
We'll see how long the rear lasts. It's a '69 4 pinion 3.55 HD unit I swapped in 30 years ago. I had monzaz rebuild it about 10 years ago and at the time he said "go easy on it". It may hold up on street tires around town, but I suspect if I ever I take it down the track it will probably check out. There might be a thread on a 12 bolt upgrade in the future.
Ken
  #348
Old 05-10-2023, 01:49 PM
David Jones's Avatar
He built the 71 Buick 8.5" under my car and it's survived 10 years or so. Moser axles and a Tru-Trac.
Great job on your car.
  #349
Old 05-10-2023, 02:03 PM
Tim john Tim john is offline
David, I always wonder how that rear is holding up, hard to believe it has been that long since I shipped it to you. I still remember the heavy duty crate I built for it ! Hope all is well with you and your family.
Tim john---
  #350
Old 05-19-2023, 01:04 AM
Verdoro 68's Avatar
I want to give a shout out to SunTuned who put in some extra effort to get my distributor back in time for the car show at my son's High School auto shop. Super stand up guy, but we all knew that already. I have a full 36 degrees now without overloading the initial timing.
The new converter is also in. I had a minor issue with a broken trans line fitting on the maiden voyage that caused a smoke show and messed up my nice clean undercarriage. Nothing hurt, just a mess to clean up. I ended up pilfering a fitting off an abandoned TH400 at the school shop to get back on the road.
The car drives way different with this converter. I definitely notice that it has a stall in it. Like the paperwork says, it stalls spot on at 3000. With a light foot, it will kick in around 2600. By contrast, the 13" Continental was around 2200 so this one is quite a bit higher. It keeps the engine squarely in the torque curve and it feels like I could pull a house off it's foundation.
It's going to take me a little bit to get used to the higher stall speed, but this converter feels right for the power band. Blip the throttle and you're very quickly sideways - it's fun
I think I'm good to just go and enjoy the car for a little while now!
ID:	612887   Click image for larger version
ID:	612888   Click image for larger version
ID:	612889   Click image for larger version
Ken
