Old 01-30-2014, 10:17 AM
Colin70TA Colin70TA is offline
Thanks for all the info Geno! I really appreciate it. The rims will be going on my 70 T/A and it has a similar suspension set up to your 72. I don't want to roll my wheel well lips but from the sounds of it I should be okay.
Thanks again for helping me out!
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15.
1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-(
1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-(
Old 01-30-2014, 04:29 PM
72blackbird 72blackbird is offline
No worries, Colin- I think you'll be okay without rolling the wheel lips if you use a rear leaf spring with a WS6 ride height. Like I mentioned there's so much room back there I may try to squeeze a 305/35R18 on a 18 x 10 later- I see don't see why an 275/40R18 on a 18 x 9 wouldn't fit in an untouched 70-73 rear wheel well.
Geno
Old 01-31-2014, 08:38 AM
HWYSTR455's Avatar
Geno
Using a 5.75 backspace? You have disc brakes back there? I'm interested in the results.
One thing I've found when trying to max size is that the sidewall buldge may contact the spring when the tire squirms around corners. Something to note...
Old 01-31-2014, 01:25 PM
HWYSTR,
I do have a factory disc brake rear end from a 79 TA- there is still at least 3/4"-1" clearance from the sidewall to the wheelwell hump. And the 18 x 9 wheel with the 5.25" backspace still has at least another 3/4" before the outer sidewall is flush with the outer wheel lip (my wheel lips are cut/rolled).
A 305/35R18 may be too much to fit properly without sticking out of the wheelwell, but there's plenty of room for a 295/35R18. Once I get my rims I'll look at them and see if it's possible to split them to get widened. US Mags does offer the Bandit in a 18 x 10 2-piece forged design, but at $600/each it's strictly for hardcore Pro-Tourers.
I also plan to go with big brakes front and rear (Wilwood), so I'll live with 18 x 9's and 275/40R18s all around until my brake and rear end upgrades are done.
Geno
Old 01-31-2014, 02:03 PM
HWYSTR455's Avatar
My lips are rolled too, so I may be able to do the 305s.
I'd like to try these on the driver, but it has the C6 calipers on it, and on the front, there needs to be enough clearance to clear the caliper. I have Centerlines on it now, tried an ARE wheel, and it didn't clear. Shoot, the Centerlines are close, like about 1/8" max. The driver is due for a set of wheels, not sure how I'm, going to approach that one yet.
If you upgrade your brakes, make sure you get the Wilwood templates and check clearances.
Old 01-31-2014, 02:51 PM
HWYSTR455's Avatar
Can someone provide the caliper measurement as outlined in the attached pic for the 17x9 and the 18x9s please?
EDIT: Guess it would help if I attached the pic!
Old 02-01-2014, 12:28 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Anybody have a picture of a set of big inch Rally IIs on a 67 or 68 Bird?
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 02-01-2014, 05:56 PM
Not my Bird but a makes a strong argument for YO rally IIs on a 1st gen Bird. They're heavier than US mag Bandits and more expensive, but do look good.
Geno
The Following User Says Thank You to 72blackbird For This Useful Post:
Old 02-01-2014, 10:44 PM
DevoBuzz's Avatar
DevoBuzz DevoBuzz is offline
Yeh that is the one negative about the YOs . I noticed a decrease in braking performance due to the weight . The YOs with 275/40/17 were 8 lbs heavier than 275/50/15 with 15x8 wheel vintiques rallye 2 Steelies.
1972 LeMans
461 stroker 10.3:1
Edelbrock D ports Scorpion 1.5 rockers
Comp Cams "Stump Puller" roller
Holley Ultra Street Avenger 770
Ram Air III exhaust manifolds
2.5" pipes Dynomax VT w/crossover
Edelbrock Performer RPM
TH350 2.78:1 10 bolt
Old 02-03-2014, 12:42 PM
Geno
Thanks!
I dont know what it is about them, but the YO Rally IIs just look off, cant put my finger on it
Old 02-03-2014, 12:45 PM
Zyman's Avatar
Zyman Zyman is offline
Originally Posted by Captainofiron View Post
Thanks!
It is the silver blueish looking center section. Even the US Mags in black look more like a Rally II to me.
"Pride Precedes The Fall"
1968 Firebird Undergoing Transformation
1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered
2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track.
The Following User Says Thank You to Zyman For This Useful Post:
Old 02-03-2014, 01:13 PM
HWYSTR455's Avatar
Argent Silver is the OE color, fyi...
Old 02-03-2014, 01:22 PM
Zyman's Avatar
I know Argent Silver. The YO R2's are not Argent Silver.
Old 02-03-2014, 01:33 PM
HWYSTR455's Avatar
Yeah, that's what I was trying to elude to.
Old 02-03-2014, 02:01 PM
I think the CAD designer just did a bad job modeling the wheel for the CNC machine, the original RallyII has some subtle curves to its design and the YO ones just look straight, flat and very squared, I think the US Mag Bandits do a better job to get the curves right
Old 02-04-2014, 11:28 PM
GTOLou GTOLou is offline
I get the impression that these are the same rims with PMD centers ...
http://www.ebay.com/itm/17x8-17x9-18...dc27de&vxp=mtr
Old 02-05-2014, 12:00 AM
niceta's Avatar
niceta niceta is offline
The space in between the spokes is too open, they are black and not grey and they are too shiny like chrome. I just don't think they look right. Just my opinion. I prefer the year one ralley 2
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes.
https://www.facebook.com/media/set/?...7567172&type=3
  #38
Old 02-05-2014, 12:45 AM
hada76's Avatar
hada76 hada76 is offline
if you mean YOs your right, he sells them
___________________________________________
the more im around people, the more i like my dogs
  #39
Old 02-06-2014, 08:55 PM
Originally Posted by DevoBuzz View Post
Anyone find out how much these wheels weigh?
The wheels have a shipped weight of 30 lbs. each.. Not sure what a 15 x 7 Rally II weighs in comparison, but the wheel/tire combo didn't seem too bad given the size of rubber going on the car.
Geno
  #40
Old 02-07-2014, 09:01 AM
HWYSTR455's Avatar
Anyone able to provide the caliper clearance measurements?
