Old 05-30-2014, 06:41 PM
archerytony's Avatar
archerytony archerytony is offline
Anyone here have pics of the lakewood lift bars installed? Looked at them on sumitts web and I dont understand how they bolt on.
www.bowhanger.com
468 poncho powered 66 cutlass
77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html
  #42
Old 05-30-2014, 08:10 PM
grandville455's Avatar
grandville455 grandville455 is offline
http://lakewoodindustries.com/media/...1312_21313.pdf
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #43
Old 05-31-2014, 02:35 AM
Nicks67GTO Nicks67GTO is offline
I have part store shocks and plan on replacing them also may try them first and if that dont cut it hop bars next
If you replace the stockers I would go directly to an adjustable shock and bypass the bilstiens if its within your budget. A Ridetech HQ or Varishock SA. The Bilstiens were a huge improvement over the stockers but they are 30 year old technology. My experience with the HQ's from Ridetech has been great so far, they have been a huge improvement over the Bilstiens even and street driving is fantastic.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
  #44
Old 05-31-2014, 03:25 AM
brut4s's Avatar
brut4s brut4s is offline
Take a look at Dick Miller also http://www.dickmillerracing.com/imag...on_Systems.pdf
  #45
Old 05-31-2014, 11:08 AM
67ramair4's Avatar
67ramair4 67ramair4 is offline
Angry Wheel Hop- Order of Importance??
The bars that are shown are NOT the ones I mentioned in my first reply! See this link below:
http://www.amazon.com/Lakewood-Div-O.../dp/B000VTTBEQ
After installing these, ZERO wheel hop, car squats and plants both tires!! Less sideways driving when under power. Also, I used 50/50 rear Monroe shocks with this combination!
Also, the instructions in .pdf from Lakewood tell you to put 8 psi in the R/H airbag, my experience has been (as mentioned earlier) is with 12 psi in the R/H bag.
  #46
Old 06-01-2014, 11:45 AM
This is a fox body, but it shows u what's going on with wheel hop and how he cured it with aftermarket arms.
http://www.yellowbullet.com/forum/sh...d.php?t=887226
Darby
  #47
Old 06-01-2014, 12:02 PM
HWYSTR455's Avatar
Nice vids!
Yeah, he's got new uppers and lowers already, which is why I was focusing on the shocks. Worn bushings is the typical cause on older cars.
There's 2 theories on the rear suspension, one is to change the instant center, which is what the no-hop bars do. Dick Miller has a good book that covers that theory, and his parts/kits are pretty good:
http://store.dickmillerracing.com/en...ldsmobile.aspx
I'm still leaning towards shocks though, and if they're junk, would be the first thing to try.
  #48
Old 06-01-2014, 07:55 PM
Cool video you can see how much he has lowered the rear of the lower bars and also how he raised the rear of the top bars I have done that with mine just not as much as him. I will see how mine works with the new shocks should have them monday or tuesday I will let you guys know how it works.
www.bowhanger.com
  #49
Old 06-01-2014, 08:00 PM
Nice vids!
Good looking stuff
www.bowhanger.com
  #50
Old 06-03-2014, 09:36 PM
I use Indian Adventures Lower control arms (now out of business) which I believe are very similar to South Side Machine's.Using those with air bags and drag shocks car never hopped and ran 10:80's with 60 ft times @ 1.5sec.
  #51
Old 06-04-2014, 02:54 PM
Got the racing shocks on 30/70 setting (comp. Eng.) from a dead stop seems to be good! Little small chirps if Im rolling 25mph and jump on it the ride is much nicer also wonder if a diff setting may get rid of the small chirps?
www.bowhanger.com
  #52
Old 06-06-2014, 05:34 PM
Maybe try 50/50 tony ... Good news man!!
Darby
  #53
Old 06-08-2014, 11:03 PM
leeklm's Avatar
leeklm leeklm is offline
Quick update... I ended up installing QA1 No-Hop bars and a set of spherical joints on frame side of upper arms, and you guessed it... NO HOP! Worked great on street tires and a set of 10" slicks at the track.
  #54
Old 06-08-2014, 11:37 PM
Good to hear. Made a set for my 66 442 4 speed and it solved the issue on the spot. IIRC GM changed the upper arm setup in 68?
  #55
Old 06-09-2014, 10:46 AM
Thats awesome glad to hear that.
www.bowhanger.com
  #56
Old 06-15-2014, 08:01 PM
Here I go again put on some old tires thought I would have a little fun and they hopped like a b#%@h.I had a idea about how the rearend rotates and after I seen some pics heres what I tryed. A piece of chain from the top bracket of the rear end and bolted it with a little play in it to the lower control arm. Went back and tryed it and the hop was gone. Took the car for a 20 mile ride and seemed to ride normal. When the rear turns up it pulls on the chain making it try to lift the car I tryed it on one side and it worked then I put it on the other side as well
www.bowhanger.com
  #57
Old 06-15-2014, 08:24 PM
Its working now
www.bowhanger.com
