Old 02-22-2019, 12:29 PM
napster's Avatar
napster napster is offline
I know its over the top....but you only live once.
ID:	506339   Click image for larger version
ID:	506340   Click image for larger version
  #282
Old 02-22-2019, 02:52 PM
David Jones's Avatar
If it makes you smile.....home run.
Looks great.
They all do. Well done folks.
  #283
Old 02-27-2019, 01:48 PM
napster's Avatar
Looks great.
Thanks.
Here one is one more.
ID:	506750   Click image for larger version
ID:	506751   Click image for larger version
  #284
Old 02-27-2019, 01:49 PM
napster's Avatar
last set.
ID:	506753   Click image for larger version
ID:	506754   Click image for larger version
  #285
Old 02-27-2019, 08:53 PM
mlund888 mlund888 is offline
Default 63 Lemans
Stroked 400, full roller 468hp
ID:	506788   Click image for larger version
  #286
Old 02-27-2019, 10:22 PM
Tanksta's Avatar
Tanksta Tanksta is offline
Default My new baby!
1967 Lemans Convertible_____Tanksta's facebook page______
  #287
Old 02-28-2019, 12:19 PM
FlyJS41's Avatar
FlyJS41 FlyJS41 is offline
Fire breathing monster, right here.
  #288
Old 02-28-2019, 02:34 PM
Bob's GTO Bob's GTO is offline
69 GTO 400
Name:	Hot Rod Portraits engine.jpg
  #289
Old 02-28-2019, 03:34 PM
HWYSTR455's Avatar
Originally Posted by Bob's GTO View Post
69 GTO 400
Nice.
Is that a Sport Track setup? Any issues with it?
  #290
Old 02-28-2019, 03:54 PM
Nice.
Yes, it's the Sport Track. No issues, very nice product.
March had the A/C compressor manifold powdercoated for me to match the kit.
I didn't use the supplied Eddy water pump, I have a Flowkooler, so I needed a few stainless shims, but the install is very straightforward.
  #291
Old 02-28-2019, 04:28 PM
NeighborsComplaint's Avatar
Pics of my 455 in my '71 GTO. Z28 air cleaner (has Holley drop base) was used for hood clearance with Holley carb and Procomp intake. All wiring and vacuum lines run under intake and behind fender wells. MSD box hidden on core support in front of washer fluid reservoir. Hard lines and brass T used for dual feed lines like RA V.
  #292
Old 02-28-2019, 04:57 PM
That Z28 air cleaner is cool, almost looks like it belongs. I might have to ditch my 71 Trans Am lid and look into one of those.
  #293
Old 02-28-2019, 09:22 PM
77 TRASHCAN's Avatar
69 GTO 400
I'd like to see more views of brackets/pulleys, when possible!
Shut it off
Shut it off
  #294
Old 02-28-2019, 11:27 PM
Bentwheelbob's Avatar
Here’s a few....1978 W72 Y88, 1972 455 HO Formula, and 1973 L75 TA with 15K miles.
Sent from my iPad using Tapatalk
  #295
Old 03-01-2019, 10:15 AM
[QUOTE=77 TRASHCAN;5997613]I'd like to see more views of brackets/pulleys, when possible![/QUOTE
Found these in the archives.
ID:	506889   Click image for larger version
  #296
Old 03-01-2019, 10:35 AM
HWYSTR455's Avatar
Very nice Bob. What did you do for the reservoir?
  #297
Old 03-01-2019, 10:58 AM
March reservoir kit includes a Corvette bracket that mounts to the front/top of the LS motor. I used the half that carries the reservoir, and added a piece to capture the bottom alternator bolt and also attach to the cylinder head face.
I know I had a pic after I welded it up, can't find it right now.
  #298
Old 03-01-2019, 11:36 AM
HWYSTR455's Avatar
Nice. And thank you.
I am thinking I'm going to run the Sport Track on my 'bird, have the Billet Specialties one on the current project car. I used the Billet Specialties reservoir on it, made a bracket. Was curious as to what you did there, always looking for ideas.
Once I'm finished this spring with my current project, will post an engine pic on this thread, but can see the 'preview' shots on the build thread, that includes the reservoir bracket I did, if any are curious.
  #299
Old 03-01-2019, 02:00 PM
I just reacquainted myself with your Judge build, had been following when I was working on my GTO. Your work is excellent, looking forward to the finished pics.
  #300
Old 03-01-2019, 03:27 PM
HWYSTR455's Avatar
Thank you! It's not going anywhere near as fast as I would like it to, I'm itching to get it on the road.
