Old 10-29-2020, 09:52 PM
71 T/A 71 T/A is offline
Default Chrome Pushbuttons on 68 GTO AM/FM Radios?
Or do they come with black ones?
Old 10-29-2020, 10:33 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Black
Old 10-30-2020, 12:27 AM
Scott Thelander's Avatar
Default pushin my buttons
oh my ....
thats a problem if they are black like 69 ....
I always thought 68's were chrome on FM's black on AM 's
krum
I must have gremlins swappin labels and tags .... in the back room ...
S T
ID:	552599   Click image for larger version
ID:	552600   Click image for larger version
Old 10-30-2020, 01:56 AM
Verdoro 68's Avatar
This is what I thought too.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
Old 10-30-2020, 05:57 AM
thepontiacman's Avatar
I used to have a 68 GTO and it had AM-FM Stereo and buttons were chrome .
Sent from my Moto Z3 Play using Tapatalk
Old 10-30-2020, 09:01 AM
My habit was to put nice chrome pull tabs on the GTO radios. Did NOT, could NOT do that with Firebirds.
Now, i run a DELCO faceplate with night lamp as a radio delete plate.
Old 10-30-2020, 11:10 AM
Gastiresandoil's Avatar
68 black buttons = am radio
68 chrome buttons = am/fm radio
The Following 3 Users Say Thank You to Gastiresandoil For This Useful Post:
Old 10-30-2020, 03:21 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
You are correct sir!
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 10-31-2020, 03:38 PM
That's what I thought too.
Old 10-31-2020, 06:10 PM
nytrainer's Avatar
I bought a 68 am/fm chrome button radio some years ago when I first started getting back into the Pontiacs. Both of my 68’s had am radios only but thought I might one day put the am/fm in.
I went to look at it again when I saw this thread and remembered I was told by someone that a 68 A Body had black buttons whether it was am/fm or am only so I figured I must have a big car radio.
2 questions, are there identifying numbers I should be looking for to make sure it’s a 68 A body radio? And also how do you flip the display from am to fm. I thought is was a combination of pressing buttons but no luck.
Thanks.
Old 10-31-2020, 09:50 PM
OG68 OG68 is offline
The FM Stereo has push buttons that are labeled AM - FM on the ends. The FM Mono has a selector dial behind the tuning knob labeled AM-FM
IIRC the B body AM-FM has a heatsink is mounted to the side of the radio. The A body AM-FM has the heat sink mounted to the back of the radio, This is done to clear the heater controls on the 68 A body.
2007 Cadillac SRX
Old 11-02-2020, 01:06 PM
Thanks.
7303362 68 Pontiac AM/FM~Stereo
7303302 68 Pontiac AM/FM
7303262 68 Tempest AM/FM~Stereo
7302762 68 Tempest AM/FM
7302752 68 Tempest AM
Old 11-02-2020, 01:19 PM
ahhhhhhhhhh
whew
the gremlins didnt get into my radio box in the back bedroom........
I know they have been in the shop tho movin stuff around :-)
also
if you dont have a tag on yours the a body tempest radio support bracket
bolts to the radio right above my 7302762 tag
the big cars are not in this position as their bracket and dash is different
Old 11-02-2020, 02:32 PM
I think they have the same mounting Scott.
Many years ago I used the 68 B body FM radio in my GTO by moving the heat sink to the rear of the radio. It bolted right up.
This is a photo of a B body stereo unit. Same mounting location as the A body.
2007 Cadillac SRX
Old 11-02-2020, 02:49 PM
nytrainer's Avatar
Thanks for all the numbers and info but I guess I got skunked when I bought it. Caveat emptor right? Looks to be from B body.
The display does roll over to am and fm but I had no knobs on the stems and forgot how. So thanks for that info.
I planned on putting radio in an uncut bezel and would either gut the radio and have modern components put in it or just have it non functioning just for the stock FM look. Don’t usually listen to radio in either convertible.
Hopefully OG68 is correct that stem spacing is the same and it will fit.
ID:	552920   Click image for larger version
Old 11-02-2020, 03:56 PM
NY, PM sent
2007 Cadillac SRX
Old 11-02-2020, 04:59 PM
Verdoro 68's Avatar
Still kicking myself for tossing a '68 AM/FM in the dumpster in the mid-90s. D'oh!
Ken
Old 11-02-2020, 08:11 PM
Stem spacing is the same. '67 or '68 Pontiac B series AM-FM multiplexes can be built into '68 GTO AM -FM multiplexes with correct side panel,,buttons swapped on '67 units, & correct small heatsink, it's been done.
Old 11-02-2020, 08:12 PM
Stem spacing is the same. '67 or '68 Pontiac B series AM-FM multiplexes can be built into '68 GTO AM-FM multiplex with correct side panel, buttons swapped on the '67 units, & correct small heat sink, it's been done.
