Old 10-09-2020, 11:10 AM
Default Going with 7” wide wheels in front, ‘66 Tempest
I scored a great deal on some 7” X 15” Rally II’s. I’m picking them up this afternoon and I’ll check the backset. Right now, I have 6’s in the front and I’d like to see if I could fill the front wheel wells a little more. With the 6’s, the wheels look like they could be outboard more. The backs look great with 7” wheels and 255/60/15 tires. On the front, I presently have 215/70/15’s. I chose those because the tire height is exactly the same as the rears. I see on Tiresize.com that this 215 tire fits a 7” wide wheel. Alternatively, I can go a little wider with 225/70/15’s. Only 1/2” wider but sometimes that makes all the difference. They are only 3/16” taller overall.
Will I have any fitment issues? I don’t want any rubbing. I just want it to look more balanced. I looked at 235/60/15’s but they are a full inch shorter than the existing tires. Definitely don’t want that.
Old 10-09-2020, 12:01 PM
The Champ's Avatar
Depending on the backspacing, you might consider trying a 245/60/15 up front. Just slightly shorter than the 255/60/15's on the back.
I ran 235/60's up front and 255/60's out back on my '64 GTO for years with 15x7" rims with 4.25" BS - photo below.
I personally don't like the idea of having a taller tire on the front than the rear.
Old 10-09-2020, 12:18 PM
225/70-15s are huge.
No way they’ll fit without rubbing.
235/60s look good and are a safe bet.
215/70s are also pretty big but you might get way with those.
Old 10-09-2020, 02:08 PM
ZeGermanHam's Avatar
A 235/60R15 is 0.74" shorter than your existing 215/70R15 fronts, and 0.94" shorter than your 255/60R15 rears.
I definitely would not use a taller tire on the front of the car. If you want to keep your 255/60s in the rear, I like the 255/60 (rear) 235/60 (front) combo as shown by Champ above.
1998 BMW 328is (track rat)
Old 10-09-2020, 04:14 PM
The Champ's Avatar
One thing you need to remember - even though the 235's are about 1" shorter, that only means about a .5" change in ride height.
Sometimes people forget that the radius (diameter divided by 2) is the number to compare when evaluating how the stance of your car will change.
Old 10-09-2020, 04:44 PM
I got the rims. 15" X 7" HM code Rally II's, 4 1/4" Backset. So that means 2 3/4" +/-deep on the outside, correct? I searched the web and it seems that the 15" X 6" wheels that I have on the front (rare, apparently) have a 4" backset. So that's 2" on the face side. So if this is the case, then the outside edge of the front wheels will be pushed outboard about 3/4" from where they are now by just switching wheels. I think that alone would make the difference that I'm lookng for and I can just flip the tires over to the new rims. Thoughts?
Name:	7 inch 1.jpg
ID:	551108   Click image for larger version
Name:	7 inch 2.jpg
Old 10-09-2020, 05:03 PM
Add another inch to your front spacing calculations, a 6 inch wheel is 7 inches from lip to lip and a 7 inch wheel is 8 inches wide overall. Put a measuring tape against a bare wheel and you’ll understand what I’m saying.
No matter, should work out fine swapping to the 7 inch wheels keeping your same tires.
Old 10-09-2020, 05:22 PM
Oh, of course. How could I forget. That's how I ended up with the 6"s. The guy advertised them as 7", because he measured the overall width. I just wanted 15's so I grabbed them.
Old 10-10-2020, 07:37 AM
The Champ's Avatar
The rims on my '64 in the photo I posted have the same BS as your new rims. The 235/60's cleared everything just fine with the drum brakes at the time. When I converted to front discs, I did experience a very slight rub occasionally, but at the time I converted to front discs I also replaced the factory A arms with GW tubular units and lowered the front end with Koni coilovers.
I now run 17's on the car and added .375" BS to solve the occasional rub that I had due to the front discs.
Old 10-10-2020, 05:17 PM
Thanks for the input, guys. All good stuff. I was thinking about disk brakes later and I've heard that they push the wheels out about 3/8". I still don't think that would be an issue, though.
I'm bummed out that I can't mount these right away. The darker portion is all wrong. The guy had them professionally finished but the darker portion is like an olive-y grey. And it's a flatter sheen than the silver. I grabbed the Duplicolor Graphite wheel paint at the store, so I'll get on that later.
ID:	551173   Click image for larger version
