Old 03-23-2024, 01:13 PM
ponjohn's Avatar
ponjohn ponjohn is offline
KRE just dyo'd pump gas 505 with 365cfm high ports. 676 hp at 6000 rpm.
  #42
Old 03-23-2024, 06:38 PM
Stan Weiss's Avatar
Very nice numbers. Anymore information like CR or cam specs given?
Stan
Pontiac Pump Gas List
  #43
Old 03-23-2024, 07:53 PM
Steve C. Steve C. is offline
Good luck ! Typically they are Secret Squirrels regarding cam specs.
Old information here:
  #44
Old 03-23-2024, 11:21 PM
Stan Weiss's Avatar
Steve,
Thanks.
I was just looking to see how close or far away it was from something I had simulated in Desktop Dyno.
Stan
  #45
Old 03-30-2024, 12:46 AM
Stan Weiss's Avatar
510 ci
650 HP @ 5900
11:1 CR
93 octane
https://www.motortrend.com/how-to/51...ech-dyno-test/
Stan
  #46
Old 03-30-2024, 08:55 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Maybe we're doing chit wrong but we made 735 on pump gas with a factory block recently. Another Pontiac builder was North of 900 with pump gas and an aftermarket block. Both builds used Hi-ports.
That Motortend build is 20 HP stronger than a members 455 aluminum D-port factory block build using a similar spec standard core camshaft but he was 46 CID less.
I would think maybe our Dyno was happy but all three engines were pulled on different dyno's.
FWIW
Go fast, see Elvis!
  #47
Old 03-30-2024, 09:32 AM
Stan Weiss's Avatar
FWIW
Paul,
You were using a 115 LSA?
Stan
  #48
Old 03-30-2024, 09:39 AM
PAUL K's Avatar
Originally Posted by Stan Weiss View Post
Paul,
Stan
Hi Stan.... No, we use the wide LSA's like that for 1,000+ NA builds and some forced induction combinations. We also used a lot less lift. Duration at .050 was about the same..... So maybe we weren't as similar as I initially thought.
That's a pretty exotic build (the Motortrend). I'm guessing it went into a big dollar pro touring type car.... Probably idles really well.
Go fast, see Elvis!
  #49
Old 03-30-2024, 10:22 AM
Paul's comment regarding engines being pulled on different dyno's is very appropriate. Dyno results can vary all over the map.
Much depends on both the facility involved and also the operator.
From the internet...
Westech has an optimized, sealed dyno cell with blow-through fans (you can barely open the cell doors with them on), plus strictly controlled coolant and oil temps.
Typically Westech's engine dyno runs start at a 140-degree F coolant temp and (at worst) end with the temp no higher than 160 degrees.
Great for generating accurate and repeatable numbers (Westech routinely recalibrates its dyno)
  #50
Old 03-30-2024, 10:28 AM
Pump-gas 535ci, 650hp at 5400 rpm
345 cfm Edelbrock heads
Torker II intake with Quick Fuel 850 carburetor
Relatively mild 248/254 XE hydraulic roller
https://www.motortrend.com/how-to/cc...-alloy-indian/
The Westech dyno wouldn't hold the engine under 3000 rpm.
At its lowest point on the readout it was already producing 600 ft.lbs. torque. Flat torque curve.
Also keep in mind here, if you were to use a solid roller cam it would have more duration than the hydraulic roller profile.
If you want the valve lift curve to be the same, the solid (Mechanical) lifter cam will be bigger at .050".
The Following 2 Users Say Thank You to Steve C. For This Useful Post:
  #51
Old 03-31-2024, 05:58 PM
ponjohn's Avatar
FWIW
Did you port the Hi-Ports?
  #52
Old 03-31-2024, 07:16 PM
PAUL K's Avatar
Hi John, the pump gas heads I did.
Go fast, see Elvis!
  #53
Old 04-01-2024, 03:32 AM
Dragncar Dragncar is offline
If I had a 505 with heads that flow just about like a set of Wide Ports and only make 676 I would not be happy.
Maybe the cam was not all that big ?
  #54
Old 04-01-2024, 07:22 AM
PAUL K's Avatar
FWIW
Just to be clear, I ported the D-port aluminum heads on the 630 HP 455 build and the 735 hp Hi-port head on the factory block build. The 900 plus Hi-port engine is a pump gas build also built by another shop.
Go fast, see Elvis!
  #55
Old 04-03-2024, 01:23 PM
HWYSTR455's Avatar
I'd be interested in knowing the general cam specs on the 735 & 900hp builds.
  #56
Old 04-03-2024, 01:52 PM
PAUL K's Avatar
265'ish @ .050 on the small build and no info on the other it was not my project.
Go fast, see Elvis!
  #57
Old 04-03-2024, 02:19 PM
Formulajones's Avatar
That sounds more like it for a 455 cam.
Dad's in the 571 is only 261 and that 598 I bought is only 258!
Both on a 112 and both hydraulic rollers.
https://youtu.be/XqEydRRRwqE
