Old 01-09-2024, 07:39 PM
lovedemnewfies's Avatar
lovedemnewfies lovedemnewfies is offline
Default Rear diff, Axel flange question
I purchased a second hand rear diff. Which has 3:55 gears and posi to replace my original rear which has 4:10 and posi. I removed the drum brake backing plates and axels to inspect the bearings which seemed real tight. I was told that this rear had been in a car that was fully restored and the owner had wanted to go to an aftermarket rear for pro touring. Anyways the question is after installing new backing plates and the Axel I noticed that there may have been an issue with the passenger side Axel bearing at one time. I think that a new or repurposed flange was installed. I don’t see that it had been welded at all. Is this required? I have some pics of the flange in question and the drivers side as a reference. Thanks for any inputs.
ID:	626307   Click image for larger version
ID:	626308   Click image for larger version
ID:	626309   Click image for larger version
Old 01-11-2024, 03:54 AM
chuckies76ta's Avatar
Well, I'm no rear-end specialist, but the two Moser rear-ends I have here, the axle housing ends are welded to the axle tubes. Check this video out where the axle tube ends and welded down lower into the axle tube then the weld is built up to same height as the axle tube itself. For a clean finish look.
https://www.youtube.com/watch?app=desktop&v=QwGZtB1ubnM
Old 01-11-2024, 12:50 PM
HWYSTR455's Avatar
That parting line/step might be just part of the flange, but not sure. If you look in the tube end you can probably see the 2nd parting line where it sould have been welded. They may have just cleaned it up on the outside.
If it's not welded, the moment you hit the brakes you will know.
That 1st pic with the casting number, that hole should be filled with a weld I believe. That secures the tube to the center section. Would be moot if the tubes are welded all the way around in that area. It might leak tho.
Did you ever see the rear in a car that was being driven?
Old 01-11-2024, 08:42 PM
I have never seen this rear in a operating car. I think at this point I’ll have the flange welded and also weld the tube in that plug hole as well. I just don’t want a disaster on the road. Thanks for the inputs.
