Old 12-21-2019, 01:46 AM
ZeGermanHam's Avatar
Default Why are the rear inner wheelhousings different
As the title states, why are the left and right rear inner wheelhousings a different shape from one another, with the driver side having a squared off rear corner? What is the most reasonable theory for why GM did it this way?
1998 BMW 328is (track rat)
Old 12-21-2019, 07:54 AM
Cardo's Avatar
Cardo Cardo is online now
I think that may be there to facilitate the filler neck on the station wagons. Then they could use the same wheelhouse for both styles. Anytime the manufacturer can eliminate a part number, they save money.
"I know just enough to keep me here, but not enough to get me out"
The Following User Says Thank You to Cardo For This Useful Post:
Old 12-21-2019, 09:00 AM
RedDirtRoad RedDirtRoad is offline
They make inner and outer wheel housings separately as well as a complete 1 piece wheel house
I thought I only needed outer wheel houses but as I got into the car and discovered more rust I needed inner ones too
My advice to you is to buy the 1 piece housing for a little more money and just cut what you need
The 1 piece housings fit better with less work
Old 12-21-2019, 11:42 AM
Jeff Hamlin's Avatar
As mentioned it was so the same DS unit could be used on all models.
Including the wagons, it indeed was for the filler necks used on the wagon.
Old 12-21-2019, 01:12 PM
Thanks for the info, guys. I figured it would be something like that. Fortunately, I don't actually need to replace the rear wheelhousings on my GTO, but I was curious nonetheless.
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 12-25-2019, 06:17 PM
goatwgn goatwgn is offline
Makes sense. I have a '66 wagon, and the filler tube passes right through there.
Old 12-31-2019, 10:02 PM
Here's an official GM cutaway display, highlighting the wheelhouse detail in question.
Old 12-31-2019, 10:28 PM
MecGen's Avatar
MecGen MecGen is offline
I was just in my trunk mucking around and was thinking " why are they different ?" And boom I found my answer.
Thanks !
Sent from my SM-T590 using Tapatalk
