Old 05-07-2020, 03:42 AM
dataway's Avatar
dataway dataway is offline
Default Scuffing E-Coat
What the preferred material for scuffing E-coat before paint? Scotchbrite OK or should I use sandpaper?
The part in questions is a core support.
Old 05-07-2020, 08:31 AM
dhutton dhutton is offline
Maroon scotchbrite pad.
Don
Old 05-07-2020, 10:12 AM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
NOT a body man! I scuff everything with scoth-brite and simply green or purple power if it is really dirty.
Blow dry it with clean hands and paint it!
Old 05-07-2020, 10:34 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Don
Maroon scotchbrite pad is the ticket !
Old 05-07-2020, 12:38 PM
ZeGermanHam's Avatar
I'm not a paint guy either, but I'd probably shy away from using Simple Green or Purple Power to clean the surface before painting. In my experience, those products leave a film that you'd rather not have before painting. Better to go with a paint prep cleaner, IMO.
1998 BMW 328is (track rat)
Old 05-07-2020, 04:13 PM
RedDirtRoad RedDirtRoad is offline
I dont trust Ecoat at all especially on the repro parts made overseas.
I normally DA everything with 180 grit and then apply epoxy primer
Remember Ecoat is the first type of coating on the metal if its bad then everything else you use, Epoxy primer, surfacer, sealer and paint is only as good as the Ecoat
The Following User Says Thank You to RedDirtRoad For This Useful Post:
Old 05-07-2020, 05:10 PM
dataway's Avatar
Maroon it is then.
I was surprised by this E-coat ... I bought this core support probably 15 years ago when AMES was in town for a show. It sat in it's box in the shed for all that time, basic shed, open eves, tarp for a door. Not a spot of rust anywhere on it, not even on the weld joints.
Jeez, found the commercial pack on Amazon ... very reasonable.
Thanks folks.
Old 05-07-2020, 08:08 PM
If you’re one of those guys who likes to use water based products the Presta Scuff Stuff is made to prep painted surfaces for paint.
https://www.prestaproducts.com/Scuff...p-details.aspx
Don
Old 05-07-2020, 10:17 PM
400 4spd.'s Avatar
If the coating on your new part washes off with a rag and lacquer thinner, it has to go to bare metal first. That was made clear when I had my PPG certification course.
We use 220 and any hard to reach shiny spots get the red scotch brite. Two coats of black epoxy, then color coat.
The Following 3 Users Say Thank You to 400 4spd. For This Useful Post:
Old 05-08-2020, 01:21 AM
dataway's Avatar
I did a lot of modification and welding to this core support ( to make the F'in thing fit), the E-coat was a pain the rear, it was very tough to remove, both abrasive or chemical ... I didn't try lacquer thinner, but I know flammable brake cleaner on a paper towel rubbed briskly would come away just barely darkened. Not sure I have any lacquer thinner in the shop, but I have acetone, MEK and enamel reducer.
Old 05-09-2020, 01:19 AM
MUSLCAH MUSLCAH is offline
ID:	539713Maroon Scuff pad....then treat any bare metal with etch primer ,let that flash for 30-60 minutes...then sealer and paint. No need to scuff the etch primer..it is wet on wet.. If it’s just going semi flat black black ....SEM make a spray bomb that goes over bare metal....slick stuff.
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 05-09-2020, 05:00 AM
dataway's Avatar
You don't hear many people mention the DTM (direct to metal) paints that are popular in industry, I assume that's what the SEM stuff is. Would be great for lots of the semi-gloss chassis parts etc. Supposedly holds up real well. Just about any major manufacturer has a line of DTM products. Also used a lot in dipping applications.
Old 05-09-2020, 11:01 AM
Got that SEM DTM paint on under hood applications going on 4 + years ...on repeat customers that keep crashing their cars...It looks like the day I put it on....no bleeding or cracking around welded joints.
Old 05-09-2020, 01:21 PM
dataway's Avatar
I found some DTM enamel at a Sherwin Williams store some years ago for dipping a metal product I was producing in volume. The dipping was a pain, but the paint itself was great, there are a few of the items still knocking around in storage for probably ten years, other than dusty they still look great.
Anything special to know about spraying it?
Old 05-09-2020, 03:18 PM
Nope ...just shake and spray....out of spray bomb
Old 05-09-2020, 05:37 PM
I’ll take SPI epoxy over 1K rattle can any day. No need for a topcoat.
Don
Old 05-09-2020, 09:17 PM
Don
Who makes SPI ? Is it a value line of DuPont...PPG...R&M...ICI Auto color...Spees....Sickens...?
Old 05-09-2020, 09:19 PM
400 4spd.'s Avatar
Because this topic has drifted (my fault) from preparation to different opinions on coating applications, I offer the link below for anyone to read. Because of my line of work I lean toward over-kill for longevity and quality. I realize that doesn't fit everyone else's situation.
https://kta.com/kta-university/recom...ing-thickness/
Old 05-09-2020, 09:33 PM
Heck Steve...The leading car manufacturers have their problems with delaminating. And we all know they have way better booths and controlled environment....and top notch materials...and paint measuring gauges......yet they ef - up. Not to mention my friends 2013 Chevy truck with rust blisters over the rear wheels......The factory primers suck too...epoxy or not.
Old 05-09-2020, 10:21 PM
400 4spd.'s Avatar
Valid point. For instance we have so many Nissan products on the roads here with clear coat delam "stripes" on the upper surfaces that it's not funny. It must be because they save on production costs with a cheap product that usually fails just past warranty limits.
