Old 01-11-2020, 03:29 PM
ZeGermanHam's Avatar
Originally Posted by RedDirtRoad View Post
I am at my shop now and just took this photo
The channel on the sail panels that are part of the rear quarters are flush with the Dutchman panel so in reality the complete channel around the whole rear window is all flush so the window sits flush too if that makes sense
Excellent, thank you!
1998 BMW 328is (track rat)
  #62
Old 01-17-2020, 10:13 AM
RedDirtRoad RedDirtRoad is offline
Default Primer
Its only epoxy primer and there is a lot of surfacing, blocking and sanding ahead but at least the metal work is complete and getting closer to paint
Doors and trunk gaps are perfect too.
ID:	528960   Click image for larger version
ID:	528961   Click image for larger version
ID:	528963   Click image for larger version
ID:	528964   Click image for larger version
  #63
Old 01-17-2020, 01:08 PM
Coming along nicely, and very quickly!
  #64
Old 01-17-2020, 03:02 PM
Mike Davis's Avatar
Looking good and making great progress in the amount of time.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
  #65
Old 01-29-2020, 09:27 PM
Body work continues
As that is happening I installed the engine and trans on the frame and installed my new Gardner exhaust.
I hope to fire up the engine for the first time this weekend.
ID:	530431   Click image for larger version
ID:	530432   Click image for larger version
ID:	530433   Click image for larger version
  #66
Old 01-30-2020, 04:52 PM
geeteeohguy's Avatar
Great thread. Your body guy and yourself have a ton of talent and are doing a first rate job, IMO. That car will be a knockout when completed. I've had 9 first-gen GTO's, and never, ever had one with high back seats. I'm jealous!!
Jeff
  #67
Old 01-30-2020, 07:42 PM
tempest1964's Avatar
Nice pipes! Gotta ask, is that cool glass complementary with the exhaust? Nice little perk if it is.
  #68
Old 02-05-2020, 06:42 PM
Thanks. Its been a busy few months of just metal work but finally have it in high build 2k surfacer and all blocked out
It took 3 rounds of surfacer and long blocking to make the body perfect and straight.
ID:	531161   Click image for larger version
ID:	531162   Click image for larger version
ID:	531163   Click image for larger version
  #69
Old 02-05-2020, 06:46 PM
Thanks, I use Gardner Exhaust. Their systems are factory correct with hangers, clamps, resonators and the 2 different size mufflers too
The Glass is just a gift that comes with every system. A nice touch since T shirts and stickers aren't my thing
  #70
Old 02-06-2020, 04:07 PM
Test fired up the engine and It started on the second crank attempt as soon as I had fuel up to the carb.
With the exception of a minor upper radiator hose leak and a transmission cooler line leak it ran just perfectly for 20 mins at 2000 RPM
Sounds great with the Gardner exhaust too.
ID:	531247   Click image for larger version
ID:	531248   Click image for larger version
  #71
Old 03-19-2020, 06:04 PM
Its been over a month since I posted but it doesn't mean I stopped working.
Since my last post I transported my running chassis to my body man and mated the body to the chassis
ID:	534776   Click image for larger version
  #72
Old 03-19-2020, 07:14 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I didn't go back and read all the posts and my mind is a steel trap. Anything that gets in can't get back out so what colors are you using?
  #73
Old 03-19-2020, 08:20 PM
Phil
Can you be more specific?
Colors for what ?
  #74
Old 03-19-2020, 10:50 PM
fyrffytr1's Avatar
Phil
Colors for what ?
Interior/exterior.
  #75
Old 03-19-2020, 11:03 PM
Gotcha
Doing original color combo
Tyrol Blue/ Parchment
  #76
Old 03-20-2020, 01:21 PM
Looking great! Did you cover your entire frame with plastic before bringing the body down to protect it from overspray?
  #77
Old 03-20-2020, 08:08 PM
Yes Karl,
My plan was to use a mattress bag you get at any hardware store nut I found out it was harder to roll the car into it then i thought. I had a few covers from Inline Tube that they sell. The are clear with elastic around the bottom so i covered the frame before setting the body on it
When I get the energy I will crawl under the car and tie each side to each other with string so the bottom is almost air tight too.
  #78
Old 03-20-2020, 08:20 PM
Yes Karl,
Smart idea. I think I'll do something similar with my project.
  #79
Old 03-21-2020, 04:26 PM
Originally the plan was to paint it on a body cart like my previous project but this car had so much metal work we wanted to put it back on the frame just to make sure all the door gaps, trunk gaps and front sheet metal would line up.
We don't want to take it off the frame now, The car will be painted with the deck lid on and doors on. Hood, fenders and all little bolt on parts will be off like the photos below
ID:	534943   Click image for larger version
  #80
Old 03-26-2020, 08:54 AM
Almost ready for paint now.
The trunk has been refinished, Floors are now painted, Kilmat installed on floor and roof.
