Rear brake line 3-way block?
Where can I find that 3 way block? I looked at our host and Inline Tube but didn't see it (or didn't recognize it).
My car has an 'O' type rear and I have a Pontiac rear that I'm going to swap in (Basic A body 10 bolt from a '69 GTO). The hose-to-hardline 3 way junction is not on the Pontiac rear that I have and I can see that the Olds rear has a different arrangement. I found the rear axle hardlines and the rear flex line but not the distribution block. Biggest problem is that I don't know what it looks like and what attaches it to the top bolt of the differential assembly.
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 10-04-2021 at 01:08 PM. |
Greg, try this for pictures - current ebay listing
https://www.ebay.com/itm/184287333023 Will search for block for you What about this? It looks to be part of the rubber hose - perhaps you have been searching for a separate block when the block is part of the hose assembly. If OPGI has one (they do), then I imagine our host does also. https://www.amazon.com/ACDelco-18J17...68+Pontiac+GTO
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) Last edited by 68gtoMN; 10-04-2021 at 01:52 PM. |
IIRC, that junction is built into the center hose where it distributes to the wheels. The center hose clips to the frame ahead of the diff where it meets the hard line.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
Ok, seems you guys are probably right about the block being part of the hose. Now what about the clip?
And thanks guys.
Greg Reid Palmetto, Georgia |
Do you mean the bracket for the hose or the clip that holds the hose to the frame?
Ames has the bracket (R189A) for $24. I'd have to go look, but I think the clip is the same retaining clip that's used on the front lines.
It would help if I knew what it looked like. I'm talking about whatever it is that is captured by the top bolt of the differential cover. Then, I'm assuming that that item retains the block somehow
That's the top bracket in my post above - R189A.
In place it looks like this:
This is who I bought from for my old El Camino and GTO.
US made https://www.ebay.com/str/brakehosesu...p2047675.l2563
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
Thanks guys. Looking at all the pictures l think l see how it goes.
Ok, l get the picture now. I need the pair of steel lines, the flex hose assembly and the bracket. Thanks again!
