Old 08-22-2020, 09:03 AM
cnc's Avatar
cnc cnc is offline
Default Rear spoiler end caps
Can someone possibly post some nice detailed pics of the shorter rear spoiler end caps
I have a set of caps from a newer year that I wish to shorten and somewhat mimic the shorter caps..
Pics on car showing length and end contour would be very helpful if at all possible.....thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 08-22-2020, 12:35 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
here are mine from my '72, one is an original factory short end cap. The other I'm pretty certain the body shop modified a later one I provided but they are the same angle visually and both are about 3/4" to the reference point from the top of the tail panel ends. Maybe someone else with the early spoiler end caps can post similar shots to verify if they measure the same
ID:	547711   Click image for larger version
ID:	547712   Click image for larger version
ID:	547713   Click image for larger version
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 08-22-2020, 01:59 PM
72projectbird's Avatar
I just measured mine, and they're about 1" from the to the top of the tail panel ends. I have a reproduction tail panel though, so I'm sure there's a little variation going on.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 08-22-2020, 05:52 PM
cnc's Avatar
cnc cnc is offline
Appreciate the pics ...it looks like the lower edge of the lower chrome of the tail light bezel is almost level to end of the spoiler cap or very close ....thanks
Old 08-22-2020, 09:39 PM
NOT A TA NOT A TA is offline
I fixed one for a customers car as part of a project repairing wheel flares and other parts. Here's the pics.
John Paige
Lab-14.com
Old 08-23-2020, 09:04 PM
Aus78Formula Aus78Formula is offline
Great pics and work, John.
Old 08-23-2020, 09:06 PM
grd777 grd777 is offline
how did you strip the of these end caps
Old 08-23-2020, 10:59 PM
Thanks Ben!
GRD777 If the question was how was the paint stripped then the answer is careful sanding for that particular job. I wanted to square up the top edge to make it crisper (but not square if that makes sense). You'll note that there's a very thin line of paint that hasn't been removed yet in the pic above. Before primer that edge was rounded slightly with finer sandpaper (because paint doesn't like sharp edges). IIRC most of the paint was removed with 80 grit on a DA till thin and then 180 by hand to remove the paint to bare plastic before priming/blocking.. I knew the car the parts came off of was painted around 1990 and the parts weren't fully stripped at that time so I didn't want problems occurring due to any of the older paints so they were all stripped.
I've also sandblasted these types of parts and every job is different depending on condition of the parts themselves, previous repairs, previous paint etc. as well as timeline & budget.
Here's a link to a thread on paint work done to the group of parts that end cap was included with. http://forums.maxperformanceinc.com/...d.php?t=800522
I do quite a bit of work like this. I'm currently finishing up a job replacing the trunk pan, torque boxes, frame rails etc. on a 67 Camaro RS SS convertible and stripping & prepping a 70-72 Firebird Enduro bumper.
John Paige
Lab-14.com
Old 08-24-2020, 07:06 AM
cnc's Avatar
cnc cnc is offline
Excellent pics and work John....thanks for tall the detail...appreciate it hope mine turn out half as good
Old 08-24-2020, 06:52 PM
unruhjonny's Avatar
I don't know if it would help, but I have an early spoiler in my garage not attached to anything, if there is some specific picture I could take for you, I would be happy to help.
1970 Formula 400
Old 08-25-2020, 08:22 PM
cnc's Avatar
cnc cnc is offline
I think I have everything needed it was more about the finish on the ends not being straight cut but somewhat rounded over ....I want it to look close to what it should be....if possible
Old 09-04-2020, 06:47 AM
cnc's Avatar
cnc cnc is offline
If u could take some pics of the tip end cap of the contour all around frt and back that would be awesome appreciate it...Chris
Old 09-04-2020, 10:45 AM
unruhjonny's Avatar
absolutely!
pictures will be posted shortly.
1970 Formula 400
Old 09-04-2020, 10:52 AM
Formulajones's Avatar
Here's a close up of original end caps on mine.
https://youtu.be/XqEydRRRwqE
Old 09-04-2020, 11:09 AM
unruhjonny's Avatar
here's four:
ID:	548668   Click image for larger version
ID:	548669   Click image for larger version
ID:	548670   Click image for larger version
1970 Formula 400
Old 09-04-2020, 11:11 AM
unruhjonny's Avatar
and three more:
ID:	548672   Click image for larger version
ID:	548673   Click image for larger version
1970 Formula 400
Old 09-04-2020, 07:17 PM
cnc's Avatar
cnc cnc is offline
Awesome great pics guys appreciate it once again
