Old 07-29-2019, 01:28 PM
Drew W's Avatar
Drew W Drew W is offline
Default Help with neutral safety switch
I just found out my LeMans Sport has no neutral safety/backup switch. How do I install one? Where does it attach? I figure I have to remove the console to get to the shifter first.
Drew
Fifteen hundred years ago everybody knew the Earth was the center of the universe. Five hundred years ago, everybody knew the Earth was flat, and fifteen minutes ago, you knew that humans were alone on this planet. Imagine what you'll know tomorrow. - K (from MIB)
1972 LeMans Sport convert (T41) '70 XF 455, TH400, 3.31 12-bolt Posi
Old 07-29-2019, 01:55 PM
F ROCK's Avatar
F ROCK F ROCK is offline
i think i remember it's on the steering column?
yes, and it might be curved to fit the radius of the column, and has a bunch of wires connected to it.
i didn't think my car had one either...until i changed the carpet and unplugged it somehow.
Old 07-29-2019, 02:52 PM
HWYSTR455's Avatar
Yeah, if you don't have your backdrive linkage hooked up, make sure the column collar is turned all the way counter-clockwise.
As mentioned, check the connectors, make sure they are connected and not damaged.
Do you have reverse lights? If they don't work, you are headed in the right direction with checking the switch.
Take a look in the service manual, it can give you some insight.
EDIT: Yes, it's on the column, close to where it passes thru the firewall.
Old 07-29-2019, 03:10 PM
Drew W's Avatar
My shift linkage is on tranny hump; not the Colum.
Drew
Old 07-29-2019, 05:02 PM
Pic of it:
That collar mentioned controls it, which has rods and linkage in engine compartment to the tranny.
Old 07-29-2019, 05:07 PM
Shiny Shiny is online now
If you aren't familiar with the backdrive linkage and don't have a repair manual let me know.
I have a 70 but expect the linkage is the same.
I'll scan a page from my manual so you can better understand.
In general, the floor shifter has a push/pull cable that rotates an input (selector) shaft on the transmission. There is a bracket on the trans input shaft with a lever arm for attaching the shifter cable end. This bracket also has features to rotate a steel rod (backdrive rod). The steel backdrive rod in turn rotates the housing on the steering column. This rotation of the column housing then moves the reverse lockout switch. So when you move the shifter, you are both changing the gear selector on the transmission AND you are rotating that backdrive rod.
This is why HWYSTR455 suggested rotating the outer column housing. Without the backdrive rod installed, manually rotating the outer housing will actuate the switch. On my car, the switch is mounted low on the column (below dash).
It is complicated until you have the photo or walk through the parts a couple times.
The whole mechanism is like the old Mousetrap game...
Old 07-29-2019, 05:19 PM
HWYSTR455's Avatar
This is the backdrive arm on the other side of the firewall, is there a rod on yours?
Old 07-29-2019, 05:48 PM
Drew W's Avatar
Well crap! I was hoping it would be as simple as bolting it to the shifter and plugging in the electrical connections
Drew
Old 07-29-2019, 06:21 PM
HWYSTR455's Avatar
They do make a conversion that mounts on the shifter, but you have to hack the harness
Old 07-29-2019, 07:53 PM
Do you have original shifter?
My car was column shift. I converted to console and used an aftermarket shifter (Hurst). The Hurst shifter did come with a shifter-mounted switch but as HWYSTR455 explains, you'd have to tie into the original wiring.. not too big of a "hack" but not "drop-in" either.
Old 07-30-2019, 07:27 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Does anyone know if 70-72 Monte Carlos have the same set up?
Mitch Kunath
Old 07-30-2019, 07:56 AM
HWYSTR455's Avatar
Pretty sure they do, yes, most GMs of that era have it setup that way.
Old 07-30-2019, 06:18 PM
Drew W's Avatar
Where can I get one of these rods? Mine is missing.
Drew
Old 07-30-2019, 09:01 PM
Drew W's Avatar
Thanks to everyone who offered help.
Drew
Old 07-30-2019, 11:29 PM
Scott Thelander's Avatar
hello
I have complete lockout assemblies
or parts
Scott
206 465 9165
