1970 ram air auto
I spoke with a man building a 1970 automatic trans am may built car. It's a basket case and missing engine but previous owner bought it in 1980 and told him it had #13 heads with a yz engine. He spoke with another expert in Altanta area and he said he had a ram air 3 auto with ac with #13 from factory. I have heard that with ac you would expect to have #13 before. I went throught this simular situation and was under impression that #12 is correct but not 100% sure. Another idea I have is that the factory ran out of #12 's and used #13 heads but no proof just an idea. The chamber is slightly bigger in #13 heads I believe bringing compression ration down slightly and was wondering if horse power was lost by this. In modern times with different fuel and adding dishing pistons not to ping with #12 are the #13 a good choice running 91 oactaine and stock style pistons or will it too ping and will need dish pistons.?
NO #13 heads on 1970 YZ from factory, ever.
If you have to lower static compression for use of lower grade fuel i would use dished pistons for correctness. JMHO |
The Following 4 Users Say Thank You to Kenth For This Useful Post: | ||
Took apart a factory original 70 GTO RA3 auto/ AC. It had original heads, #13, rotted out sitting on cape cod. Low miles car.
Yes lower CR CAN HELP with vacuum, and driveability with AC. Have seen a few auto RA birds with 13 heads as well, 1 was a original calif car. Other made in CA and sent to Texas.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
#12 or #13
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
All Pontiac V8īs were assembled at Pontiac plant #9 and the V.I.N was stamped at the vehicle assembly plant anywhere in the country, so how would the #13 heads got to an engine built with #12 heads? Plant #9 did not know the YZ engine would end up in an AC car, Firebird or GTO, they just knew an YZ engine is an YZ engine and YZ engines uses #12 heads. AFAIK
The Following 3 Users Say Thank You to Kenth For This Useful Post: | ||
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
It's unfortunate, but there have always been the corner cutters, anything to save a buck on a poorly thrown together build.
Another earlier example: https://forums.maxperformanceinc.com...d.php?t=739073
And so we have many Pontiacs with Factory #12 heads, that are NOT Ram Air engines as well, made in Pontiac plant 9. " GASP!!). Just saying, making more of this than it is. Now $2,000 plus to get a set of large valve heads completely done ( right).
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
This topic is very controversial from all group experts. Now I believe both are correct from what I have learned. Did these heads have drippers on yz and ws engines being #12 or #13. My yz is a factory 4 bolt main.
Again, #12 heads is used on 1970 WT, WS and YZ engines.
#13 heads is used on 1970 WX, XH and YS engines. Pay attention on the engine codes, finding #13 heads under the hood of a 1970 RamAir III car may indicate a Grand Prix engine replacing the blown up original engine. All 1967-70 4 B.C. engines, exc. RAIV, XV 400 and YH 455, uses the #9780969 baffle on the heads under the valve cover. |
The Following 2 Users Say Thank You to Kenth For This Useful Post: | ||
WT is NOT a Ram air engine.. , and yeah, it has #12 heads. Oh, and could get AC Too!
Baffles
And you could get AC on a 1970 RAIII car too. FWIW |
4 B. C. means 4 Barrel Carb and engines with #12 heads got Quadrajets, so yes Ram Air III engines got got the baffle rocker drippers too.
The Following User Says Thank You to Kenth For This Useful Post: | ||
The 70 YZ 's that i have had or seen over the years had 12's.
Had a guy who had a XH transplanted in a 70 TA and told me that brother of original owner said the 13's were original on that car. I went to his garage and date codes matched the XH block in car. Intake, exhaust, carb and brackets/pulleys were original and dated to car. XH block and 13's were Jan 70 dated. Car was a early June build. correct parts were may dated.
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
The Following User Says Thank You to thepontiacman For This Useful Post: | ||
Xh
The Following User Says Thank You to Transamric For This Useful Post: | ||
1st picture: original 1970 YZ block w/AC - 12s with baffles.
2nd picture: rebuilt 1969 WT block - 13s with baffles. 3rd picture: 1969 dated 12. 4th picture: touched 12 for early 1970 YZ block.
So long, farewell. |
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
Shields on valve springs were not used on 1970 Ram Air or 400 M/T #12 heads from factory.
In fact NO Ram Air heads got the shields due to stronger valve springs used on these heads. |
