EFI Tech All things EFI and making classics modern!
Old 03-18-2023, 12:57 AM
R 70 Judge's Avatar
They found a good spot for the Motion Raceworks E85 flex fuel sensor. It’s right above the tank mounted to the brace that holds the fuel strap. It will be on the -8 ptfe return line right before the pump.
ID:	609027   Click image for larger version
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
  #42
Old 03-18-2023, 11:04 AM
Scott65's Avatar
Scott65 Scott65 is offline
Looks good, nice work. So you didn't end up using the hellcat pump? What dissuaded you?
  #43
Old 03-18-2023, 03:47 PM
R 70 Judge's Avatar
Thanks! Funkhouser race cars is doing a great job on the car. No I didn’t use the hellcat pump. It’s actually for sale for a very good price in the classifieds. I plan on going with a 88mm-94mm single turbo or possibly twin 70mm-78mm next year so I’m planning ahead for fuel system. Better to have too much fuel than to be cutting it close.
James
1970 Trans Am
  #44
Old 03-18-2023, 04:12 PM
Scott65's Avatar
I guess I was more curious as to why you chose Holley's instead of adding a second Hellcat pump. Understand completely on wanting to have plenty of fuel!
  #45
Old 03-24-2023, 07:04 PM
R 70 Judge's Avatar
Coil brackets are done. Making progress. The Terminator X will be going in soon.
If anyone needs a set of these coil brackets let me know and I’ll get a price. Same for the remote power steering brackets.
ID:	609605   Click image for larger version
ID:	609606   Click image for larger version
James
1970 Trans Am
  #46
Old 03-24-2023, 07:45 PM
Scott65's Avatar
Looking good!
The Following User Says Thank You to Scott65 For This Useful Post:
  #47
Old 05-11-2023, 12:12 AM
R 70 Judge's Avatar
Small update. Fuel lines are and regulator are done. Sensor distribution block in. Having some clearance issues with the idle air control motor. It hits the inside of the shaker scoop. I found that Kinsler fuel injection makes a remote IAC set-up. So the new plan is the mount the remote IAC somewhere in the back and to tap into one of the open ports on the Steve Morris elbow. It’s a nice looking piece in the pictures. It uses a -10 AN fitting which should make install cleaner. I ordered the Wilson’s block-off plate as well. Hope this works.
IAC housing
https://kinsler.com/Shop/product/rem...-flow-housing/
Filter
https://kinsler.com/Shop/product/fil...e-iac-housing/
ID:	612420   Click image for larger version
ID:	612421   Click image for larger version
ID:	612422   Click image for larger version
ID:	612423   Click image for larger version
James
1970 Trans Am
  #48
Old 05-11-2023, 06:25 AM
Scott65's Avatar
It should work just fine as long as it's compatible with the Holley ECU. It's just a controlled air leak. Looking good, keep up the updates.
  #49
Old 05-11-2023, 06:36 AM
Which radiator top plate did you use?
  #50
Old 05-11-2023, 07:52 AM
Scott65's Avatar
Not sure if it's too late to make a change, but I'll throw this out there in case others are heading this direction.
https://www.motionraceworks.com/prod...lack-10-160blk
These have a very low profile LS style IAC arrangement, and interchangeable inlets with v-band style clamp rings already on them. Come in the solid linkage shown or traditional LS cable style.
  #51
Old 05-11-2023, 10:17 AM
R 70 Judge's Avatar
The shop (Funkhouser Race Cars) made it by hand
James
1970 Trans Am
  #52
Old 05-11-2023, 10:23 AM
Gotcha. And they did the lower brackets too?
That's one item I have to address, I have a make-shift one at the moment for the A body, will just have to figure it out I guess.
The 2nd gen ones are available from restore-a-musclecar, so I have the T/A figured out:
https://store.restoreamusclecar.com/...r-Bracket.aspx
  #53
Old 05-11-2023, 10:31 AM
R 70 Judge's Avatar
I appreciate the suggestion. If I was starting from scratch I’d give that one a try. Not sure if it would be enough clearance but it is definitely lower profile than the Wilson’s piece. It would be cheaper overall as well. My Wilson’s ford style 105mm billet dual seal throttle body was $565, the Wilson’s IAC adapter was $150 and the throttle bracket was $125.
James
1970 Trans Am
  #54
Old 05-11-2023, 10:40 AM
R 70 Judge's Avatar
Yeah they did upper and lower. I can ask how much it would be to produce another one if you like? Since my TA is still there to use as a template it should be possible. Just comes down to how much $ it will be.
If anyone wants a duplicate of my remote power steering set-up, speak up now while the car is there. It’s a pretty slick set-up and uses an AllStar 1600psi pump for use with the hydraboost. I went remote because the factory pump location interferes with the Stainless Headers turbo manifold. This gives me plenty of space
James
1970 Trans Am
  #55
Old 05-11-2023, 10:43 AM
Scott65's Avatar
I understand. The main draw to me is the replaceable inlets, and never having to weld on the throttle body to have a v band attachment. I've resisted the urge to change to an elbow arrangement so far, but if I do, I'll use one of these throttle bodies.
  #56
Old 05-13-2023, 11:43 AM
R 70 Judge's Avatar
Finding plug wires has been a challenge. The offerings that fit Holley smart coils is pretty limited. I ended up using Moroso Ultra 40 #73849 which are advertised as 11” long. I wish they were 1”-2” longer. I suppose I could’ve just had some made.
ID:	612551   Click image for larger version
ID:	612552   Click image for larger version
ID:	612553   Click image for larger version
ID:	612554   Click image for larger version
James
1970 Trans Am
  #57
Old 05-13-2023, 11:52 AM
Scott65's Avatar
Truck length are longer by about an inch and a half... If you can find those in that wire.
ETA: I can measure a replacement truck wire for exact length if it helps.
  #58
Old 05-13-2023, 12:13 PM
R 70 Judge's Avatar
Yeah truck length would be just about perfect (12”-13”) but I have yet to see any manufacturer making them with the smart coil end.
James
1970 Trans Am
  #59
Old 05-13-2023, 12:20 PM
Scott65's Avatar
There is a company (I forget the name) that the LS crowd favors, that will make them to your dimension. A Google search will probably turn them up. If not I can find it on LS TECH, if you want.
ETA: Firecore is the name. You can specify ends, length and have a set that fits like you want.
  #60
Old 05-18-2023, 11:11 AM
R 70 Judge's Avatar
I need them ASAP so I ordered a set of build your own Moroso Ultra 40’s and added the heat shrinks and protective sleeve ($$$). The Moroso fab shop said it would be 4-6 weeks for them to build them. I called several vendors and no one seems to have an “on the shelf” set with the Holley smart coil ends in truck length. Good news is I will have the materials to build extra sets if needed.
The Kinsler remote IAC arrived yesterday. Things are going to start happening fast in the next two days.
James
1970 Trans Am
