Chip, I have pictures of the current Fbody I'm restoring using the Inline 1/2" stainless prebent lines.
They aren't very good pictures, I'm not a photographer, but I'll see if I can take a better one to give you an idea if it helps?? |
What clips are you guys using when installing 1/2” prebent lines? I didn’t find anything on Inline Tube for 1/2”
Thanks for all the input. Noticed everyone runs 1/2 line for return. I am running 3/8 for feed linne. Will 3/8 return line ber suffcient. Engine is 455 with ram air iv cam and Kauffman heads. Right now 750 holly but want to switch to quadrajet.
If the pump is running "X" amount of fuel thru a 3/8" input line at say 42 psi, and the engine is using 2% of that flow at idle, the pressure is high but the actual flow after the engine fuel rails or Throttle Body Injection is low because the return line has basically minimal restriction back to the tank. You need the larger line IF the regulator cannot dump the excess fuel back to the tank quick enough.
An easy way to tell is install a second fuel pressure gage after the regulator and before the fuel tank. Try that method first. For years OEMs ran the 3/8" feed line and return line systems with EFI on engines without issues using the 255 liter fuel pump. Tom V.
You flared the SS lines? Or use compression fittings? .
The challenge with my setup is I've Got The Regulators on the passenger side fender. can I run the fuel lines up the driver side and then run under the engine to The Regulators? Nitrous solenoids and the carb fuel Inlet face toward the passenger side.
The ideal situation if you wanted to keep the regulators on the passenger side would be to run two Chevelle fuel lines on the passenger side. one line 3/8" for the feed and a second line either 3/8" or 1/2" back to the tank. The fuel line people sell both sizes for the Chevelle. I have a Chevelle line on the return (passenger side) of my 64 GTO. I used a 66 Chevelle application. Reminder, I also have a Tanks, inc fuel tank for a 1964 GTO.
Tom V.
Also, now that I think of it I probably would have had to alter the ending location since I had a regulator where the pump goes originally. YMMV
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
https://www.speedwaymotors.com/Fuel-...ro,116968.html
I've gotten the stone guard for all the other smaller lines, use it specifically for brake lines. It can hide choppy bends too! Heheh! .
They do. The Right Stuff put it on my line. I bought some extra Tar wrap from them in various sizes, but I didn't get any of the steel loom.
http://www.forums.maxperformanceinc....=1%2F2+install You can run a 'T' fitting on the output of the first regulator, into a deadhead type regulator, and go to the N2O fuel sol from that. If you're not using the N20 fuel regulator for tuning, and you're running a carb, just run a line straight from the 'T' in the 1st regulator directly to the fuel sol. Steel line is better than aluminum, but it's hard to manage/bend, and transitioning from hard steel line to AN is a little more difficult. (you should use a compression type fitting spec'd for steel) I've had no issue running aluminum lines, and have 100s of 1000s of miles on aluminum lines. I guess it's kind of a personal preference which way you choose. .
I like TV's idea of using 2 chevelle fuel lines, if they would fit decently. Can those be installed with body on frame? I've got engine and tank out for upgrades. I was running a sumped tank, external Comp 140 and 8AN lines. All that gets in the way of tailpipes, so I want to go to a Tanks Inc internal-pump setup.
InLine does have steel lines, and stainless steel, in coils. Stainless 1/2" for a 25' roll is around $100.
I'm sure others carry it too, just have to shop it. .
Chiphead in your case could you....use the stock shaped line in 1/2" S/S up the driver side to the wheelwell area. That would be easy to put in place.
Have them put an AN fitting on the ends. Then as you say run some PTFE hose/braided along the crossmemeber close to where the brake line is routed. would that work? FYI I have some aluminum 1/2" coiled left over. let me see how much I have. If you need it I'll ship it to you.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 Last edited by vidguy; 01-30-2019 at 04:50 PM. Reason: See he was talking about a GTO not a 2nd Gen |
Yes SF connectors I run one line down the drivers side one down the pass side.. I'll see what I have for pics....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 01-30-2019 at 10:35 PM. |
#38
More pics
The last one here u can see the RobbMc regulator mounted where the old Mechanical pump was...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
#39
I see now, was having an issue imagining the line run(s) around where the line on the passenger side crosses over from the inside of the rail to the out side, when running frame connectors.
My thought on an a 2nd gen F-body was to run 2 lines together in the OE position on the passenger side, hence the questions. Thank you for posting the pics, excellent reference. EDIT: So the last pic in post #37 is before the subframe connector was installed? .
. 1970 GTO Judge Tribute Pro-Tour Project 535 IA2 http://forums.maxperformanceinc.com/...d.php?t=760624 1971 Trans Am 463, 315cfm E-head Sniper XFlow EFI, TKO600 extreme, 9", GW suspension, Baer brakes, pro tour car https://forums.maxperformanceinc.com...ght=procharger Theme Song: http://www.youtube.com/watch?v=7zKAS...ature=youtu.be Last edited by HWYSTR455; 01-31-2019 at 10:06 AM. |
#40
IMO this would be the best material to make fuel lines out of.
https://www.amazon.com/Copper-Nickel.../dp/B01FOKISGI It will last forever and is VERY easy to bend, compared to Steel or SS line. |
