67 GTO Sterring wheel question
I want to remove my sterring wheel and replace my spokes, i have the 3/4 nut off do i have to rent a sterring wheel puller to get the wheel off?? Secondly COrrect position of the sterring wheel spokes go 3 oclock 9 oclock and 12 oclock or does the 12 oclock on the bottom???
3-9-6 for the spokes,the shaft and wheel should have a mark to line up.Yes you will need a puller.....JB
Thank You 9901, my wheel was off a full 90 degree,s, should i also clean off the white contact under the wheel that holds the spring?? It has alot of grease build-up on the copper area.
Put a little dielectric grease on it @ re-install.....JB
Thank You very much, Rich
What options do i have for sterring wheels for my 67 gto, i have the original black one and a torqios one, Both are stretched and horn spokes are cracking when installation.
Some people have had good luck with the do-it-yourself steering wheel resto kits. I think POR-15 makes one...Also Eastwood. From what I've seen, if you take your time you can make it look real good. I'll probably go that route on my '68 wheel.
Greg Reid Palmetto, Georgia |
