Old 10-04-2021, 04:20 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 1967 GTO HO
BaT auction.
Cool, rare car.
1967 WV code. Total production, 914.
Still retains all the goodies under the hood that an 360 HP HO 4 speed would have.
Only thing I see missing is the snorkel air cleaner, tube from air cleaner to valve cover and hose from pump to air cleaner.
Fix the interior and all the mechanics and drive. It will be a looker.
This car came with black painted wheels and standard hub caps originally.
ID:	574410   Click image for larger version
ID:	574411   Click image for larger version
ID:	574412   Click image for larger version
ID:	574413   Click image for larger version
Old 10-04-2021, 04:49 PM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Love the pinstripes on the glove box! Head Rest car!!
Old 10-05-2021, 02:13 AM
Nice. Here's the direct link.. https://bringatrailer.com/listing/1967-pontiac-gto-47/
Old 10-05-2021, 06:30 AM
DANTIP DANTIP is offline
Default WV
Interesting to see a California smog car built in Pontiac, MI rather than Fremont, CA??
Old 10-05-2021, 09:29 AM
Sloan66's Avatar
Default Boxed Upper control arms
60stuff educated me yesterday on the upper control arms being boxed. Searched forum today for more pics and info. Here is more proof of HO cars receiving them, if you watch the video you will see them.
The Following User Says Thank You to Sloan66 For This Useful Post:
Old 10-05-2021, 10:23 AM
60sstuff's Avatar
The ‘67 HO and Ram Air cars were built with some unique components.
1) With the heavy duty rear axle you received upper rear control arms that were “half boxed”. You can also see the frame stiffeners in the first two photos.
2) Another feature of these cars were the two front brake lines had cooling coils wrapped around them because of the heat generated from the large exhaust manifolds.
3) Last photo shows the wire harness and positive battery cable for these cars which travels down the front left side of the engine, along the block, through a sleeve mounted to the LH motor mount and ending at the special starter solenoid.
ID:	574487   Click image for larger version
ID:	574488   Click image for larger version
ID:	574489   Click image for larger version
ID:	574490   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 10-05-2021, 11:20 AM
ZeGermanHam's Avatar
I made that comment in the auction site, too. The car was said to have been in Ohio and Colorado, but no mention of spending time in California but it has a solid floor and CA black plates. I'm no expert, but I wasn't expecting to see a Pontiac built GTO with smog equipment.
1998 BMW 328is (track rat)
Old 10-05-2021, 11:54 AM
60sstuff's Avatar
This car sold New in California. That’s why it has Original period ‘67 Black and Yellow plates.
Paperwork backs it up.
I know of several 66-67 Smog cars that were built back East and sold New in California.
ID:	574493   Click image for larger version
Old 10-05-2021, 11:58 AM
Thanks for the info. Would building a smog-equipped car and shipping it across the country to CA been somewhat of an infrequent occurrence? Any idea on why the Fremont plant wouldn't have been solely responsible for building all the A.I.R. cars?
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 10-05-2021, 12:15 PM
george kujanski's Avatar
"two front brake lines had cooling coils wrapped around them because of the heat generated from the large exhaust manifolds"
I have always wondered what the purpose for these were. I've heard of them referred to as rock shields, but I have no idea.
What are they? Could they be there to prevent kinking during bending?
George
Old 10-05-2021, 12:29 PM
60sstuff's Avatar
George
George,
Those coils wrapped around the front brake pipes / lines are exactly what I said, they help dissipate the heat from the brake line because of those Large Hot exhaust manifolds.
They weren’t used in the bending of the brake pipes as “Non” HO / Ram Air cars do not have these coils.
Notice that the brake lines running down the frame and to the rear drums do not have these cooling coils.
MPC showing these cooling shields listed for the ‘67 HO and RamAir.
Chris
Old 10-05-2021, 12:33 PM
gto19's Avatar
gto19 gto19 is offline
Here is some pics of the coils wrapped around the brake lines from my car
ID:	574496   Click image for larger version
The Following 2 Users Say Thank You to gto19 For This Useful Post:
Old 10-05-2021, 12:35 PM
60sstuff's Avatar
There is a good example from a ‘67 HO.
Notice how the coils are located right next to where those Hot manifolds would be.
Thank you Eric.
Old 10-05-2021, 12:50 PM
It's kinda hard to see in the photos above, but the spiral shielding was used on the fuel & brake lines near the rear of the car where they pass through and over the driver side mounting bracket for the lower control arm. If you go to the original Bring A Trailer listing and look at the higher resolution photos, you can see it (also see attached photo from the BaT listing).
My '66 had them in that rearward location from factory, as did all A-bodies I would assume. So to say the spiral shielding was used exclusively for heat protection is not entirely accurate. In the forward location on this H.O., they helped protect from heat. In the rearward section, they helped protect from abrasion.
Edit: I just had a thought... Could the spiral coils have been used in the rearward section to protect from heat generated by the muffler rather than for protection from abrasion? Maybe it serves both purposes?
Old 10-05-2021, 01:21 PM
60sstuff's Avatar
Mr. Ze,
Good observation!
I agree with you. At the rear they probably needed that extra layer of protection from possible crushing / damaging of the brake pipes in tight areas.
Here are clearer photos of the front brake pipes that were posted above.
ID:	574505   Click image for larger version
Old 10-05-2021, 01:44 PM
OG68 OG68 is offline
Agree with all the above but...
what about from the master cylinder to the distribution block?
No exhaust heat at the top, at the bottom by the distribution block, yes.
Why protection near the MC?
ID:	574508   Click image for larger version
ID:	574509   Click image for larger version
2007 Cadillac SRX
Old 10-05-2021, 01:48 PM
Ed: I have always wondered about that as well.
Old 10-05-2021, 02:22 PM
I think Pontiac did it for work flow mainly? If Fremont had too many cars on order (for the week/month?), Pontiac plant would build some to fill in the flow.
Here's the BHC with some info on it:
The Following 3 Users Say Thank You to johnta1 For This Useful Post:
Old 10-05-2021, 03:42 PM
Keith Seymore's Avatar
This is correct.
Final assembly location was not assigned solely on geography, but could also be assigned based on unique content or to fill in additional production volume to meet demand.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 10-05-2021, 04:28 PM
60sstuff's Avatar
Very good discussion on the use of the brake line shield.
I’ve never seen this coiled metal shield on 64-66 Tempest Series cars in the engine bay.
I have seen it starting in 1967 below the master cylinder.
I’m going to assume the automotive industry used this shielding for Flex and heat related reasons.
Heat rises and the master cylinder is up top. You want to prevent heated brake fluid in that cylinder.
Flex - master cylinder is fixed to body.
Distribution block is on the frame, which flexes with the body.
My initial statement pertained to the HO and Ram Air front brake pipes.
There is no flexing on those as they are clamped to the frame before they mate to a rubber hose at the inner fender skirt. Plus no close proximity to rubbing, crushing, etc.
I’ve owned three ‘67 HO cars over 45 years of collecting GTO’s and all of them had the T/8 “SHIELD, brake pipe” that’s listed in the MPC for the High Performance ‘67.
