Old 08-17-2023, 07:49 PM
Gator67's Avatar
Gator67 Gator67 is offline
It's been a busy month, but I addressed the issues I mentioned in my previous post, and drove the car another hundred miles. She still runs good.
I did hear a squeak pulling into the driveway, and realized I did not grease the suspension when I installed it. What are folks using these days for that application? The grease in my gun would work I guess, but it's at least 20 years old--maybe 30, and I have no idea what it is.
I think I'm also going to paint the bottom of the front bumper lip black. I'm not sure if this is correct or not, but I think they look better that way. I forgot to ask Randy to do it when he painted the car.
  #482
Old 08-17-2023, 09:23 PM
I say do it.
  #483
Old 08-18-2023, 05:15 AM
HWYSTR455's Avatar
I use the heavy duty red chassis grease, commercial/fleet valvoline stuff, works really good. There's other brands but the valvoline is easy to find. I think the last tube I got was from Tractor Supply, but not sure.
It flows really easy, if you have a pump gun it's easier to pump in. Wipes off pretty clean too, and doesn't end up all over everything. Well, not as easily anyway.
  #484
Old 08-18-2023, 05:24 AM
HWYSTR455's Avatar
Yeah, I painted my bumper lip black on the bird, IMO, it does look better. Lighter body colors it has a more dramatic effect, so it kind of depends. I personally don't care for the look of the bumper bolts down there, otherwise I might not care, haven't thought about it in a while.
  #485
Old 08-19-2023, 09:16 PM
Hi Jeff, looking great!
Yes, from the factory the bottom vertical flange of the front bumper would have been black. The "lumps" on the bottom of the front valance that I circled in the pic were also painted black.
  #486
Old 08-20-2023, 09:32 AM
Gator67's Avatar
Thanks Keith. These things are going on my to do list!
But I haven’t had any luck finding a photo of an original valence to see how the lumps on the bottom were done. Does anyone have a photo they could share or point me to a thread?
  #487
Old 08-20-2023, 10:05 AM
Great looking car you built Gator.
Very trick , but subtle
Congrats and Enjoy.
  #488
Old 08-20-2023, 10:40 AM
Gator67's Avatar
ahh, spoke too soon...I found a photo online of what looks to be an original valence.
The Following User Says Thank You to Gator67 For This Useful Post:
  #489
Old 08-20-2023, 01:44 PM
That's a good example.
  #490
Old 08-20-2023, 07:57 PM
grd777 grd777 is offline
is this what you mean. i know on my mustangs they also blacked out the pinch welds
  #491
Old 08-20-2023, 08:25 PM
Held for Ransom's Avatar
An old thread...
https://forums.maxperformanceinc.com...d.php?t=696449
So long, farewell.
  #492
Old 08-20-2023, 08:40 PM
this old thread talks about the flat part of the rocker was also blacked out ,does anyone have a photo of this
  #493
Old 08-21-2023, 09:35 PM
could this have been done from dealers .Wonder why some of the guys here with original cars don't have the black out
  #494
Old 08-22-2023, 07:25 AM
HWYSTR455's Avatar
Maybe it's a by-plant thing, or mid-year change is what I'm thinking. But don't know for sure.
  #495
Old 08-22-2023, 06:07 PM
very odd that there is not of info on this
  #496
Old 08-22-2023, 08:25 PM
No clue on rockers. Some other threads...
https://forums.maxperformanceinc.com...d.php?t=553320
https://forums.maxperformanceinc.com...d.php?t=785125
https://forums.maxperformanceinc.com...d.php?t=806078
So long, farewell.
  #497
Old 08-22-2023, 08:48 PM
thank for this . it is great to find out things like this
  #498
Old 08-25-2023, 08:46 PM
Gator67's Avatar
I've had a couple people ask about the Bowler shifter I use with the T56 Magnum, and how it addresses the tendency of shifters on this transmission to develop leaks, especially when mounted in the forward position of the rear compartment (which locates the shifter directly above a big gear in the trans). The original Tremec shifter (and variants) use a rubber boot to seal the fluid, and over time, the boot deforms or tears, resulting in fluid making its way up through the shifter stub. The Bowler design uses a polymer ball that's pressed onto the shifter stub, which sits on an o-ring. The ball-stub assembly is capped with a couple pieces that keep the ball pressed to the o-ring. With mine in the forward position, it still leaked a little, so they built one using a special silicone to seal the ball so that nothing can flow through it. So far so good!
ID:	618806   Click image for larger version
  #499
Old 08-29-2023, 05:58 PM
Gator67's Avatar
The squeak I mentioned in a previous post turned out to be the hood latch pull rubbing against the bracket attached to the core support. The little plastic grommet cracked and fell out of the hole in the bracket. As shown in the photo, I was able to fit the grommet back into the hole, but it's brittle and fits loosely, so I suspect it won't hold up. I found a couple brackets with these grommets in my pile of spare parts, but these grommets appear to be similar in condition. I could glue it I guess, but before I go there, thought I should check to see if these are available anywhere (or perhaps there's another good solution).
  #500
Old 08-30-2023, 07:12 AM
HWYSTR455's Avatar
Yeah, those are repopped.
