Old 12-06-2023, 01:53 PM
Cammer-6 Cammer-6 is offline
Originally Posted by GTO Yea View Post
I'm a very satisfied customer. Here are some before and afters of my dash:
I think the turnaround time from when I shipped it out late last summer was around 1.5 months.
how much was it to redo your pad?
I see a pad for 67 GTO listed but no description as to is it a recover or a repop.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 12-31-2023, 09:04 PM
graygator graygator is offline
FYI, Al Knoch has a 10% off (over $500) until January 5th.
Kent R.
The Following User Says Thank You to graygator For This Useful Post:
Old 01-16-2024, 02:43 PM
webfoot's Avatar
webfoot webfoot is offline
I had the dash pad for my 1962 catalina done by JD, cost was what is being quoted here and it is a very minimalistic design. Only comment is there was a spot where the dye rubbed off in shipping, but they supplied a bottle of dye with the pad.
Wasn't aware of the Knoch option or I would have went with that.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 01-16-2024, 04:36 PM
I have 2 already shipped to them
Give it a month and we will see.
Old 01-18-2024, 04:14 PM
I ordered a dash refurbishment on-line from Al Knoch and then called them on 1-2-24. They called on 1-8-24 after receiving my core to clarify a couple of things. I got it back today (1-18-24). I got the Christmas special price, 10% off. This is a 69 Lemans A/C dash. I'm pretty satisfied. There are a couple of very small dents visible in one of the pictures. But some of what you see that isn't perfect isn't normally exposed as it will be covered by trim in the switch area. Notice that they did not cut out the radio opening or the switch openings. You may also notice that one of the two metal tabs below the steering column looks bent. Not sure if I sent it like that to them or not. Dash was well packed for shipping by them.
ID:	626735   Click image for larger version
ID:	626736   Click image for larger version
ID:	626737   Click image for larger version
Kent R.
Old 01-18-2024, 07:00 PM
how much was return shipping?
Old 01-18-2024, 10:05 PM
Al Knoch charged me $115 for return shipping via FedE, which is almost the same as I paid to ship the core to them using the other shipper. I homemade a box as small and tight as possible to ship the core. They are near El Paso, TX and I'm approximately 825 miles away in Shreveport, LA.
Kent R.
Old 01-23-2024, 12:38 PM
got 2 pads back today 65,&67 GTO
both look great with an exception on each.
ID:	627013   Click image for larger version
Old 01-23-2024, 01:34 PM
so question is does the plastic insert for retaining screws fit the 67?
Ames shows it as A259W but doesn't specify year
Old 01-23-2024, 01:44 PM
HWYSTR455's Avatar
Pretty sure that takes those yellow oval inserts that has a slit in it which the screw goes in.
Old 01-23-2024, 04:17 PM
and you have a picture and part#?
Old 01-24-2024, 08:14 AM
HWYSTR455's Avatar
Sure, here ya go....
Old 01-24-2024, 10:46 AM
did you read post 29?
Old 01-24-2024, 11:23 AM
HWYSTR455's Avatar
Yes. I would think for $1 its worth a shot, or call Ames maybe?
Pretty sure those are generic and are used over many years.
Did you try one and it didn't work?
Old 01-24-2024, 04:03 PM
no havent ordered any yet
waiting to put it on a bigger order
I agree,for $5 its worth the risk.
Im just pissed because the core I sent had all of them intact.
Perhaps they are removed to refoam,but one old one was left.
Old 04-03-2024, 05:32 PM
kpbrown31 kpbrown31 is offline
Originally Posted by Redpiston View Post
I looked at Al Knock website. Do they restore 66 Catalina dash pads?
I'd be curious as well. Looks like we are both 66 Catalina owners in KC
