Old 04-09-2021, 08:25 PM
462gto 462gto is offline
Default Ames 1964-74 A-body motor mounts
It looks like Ames has new motor mounts available for 1964-74 A-body cars.
Part number N226A is for reproduction mount that is supposed to be thicker metal .150 thick compared to the Anchor .115 thick metal and proprietary rubber.
Part number N242A for Torq lok mounts.
The Following User Says Thank You to 462gto For This Useful Post:
Old 04-10-2021, 10:42 AM
scott70's Avatar
scott70 scott70 is offline
None for the longer 455 frame mount?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 04-10-2021, 12:16 PM
ZeGermanHam's Avatar
I was pleased to see the addition to the catalogue, too. I'm probably going to buy the Torq Lok mounts for my '66 build pretty soon.
1998 BMW 328is (track rat)
Old 04-10-2021, 12:27 PM
66beaumont's Avatar
66beaumont 66beaumont is offline
Just ordered a pair of those yesterday, figured may as well replace while engine is out for reseal also going to one piece pan gasket
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
Old 04-10-2021, 03:59 PM
Half-Inch Stud's Avatar
Im gonna bite when my spare 455 is done.
Old 04-24-2021, 05:46 PM
Tim Corcoran's Avatar
I just ordered a set of the Torq Lok mounts for my 67 LeMans and will see if they hold up as the ones that were in there were broken. The polyurethane mounts look like they are getting them from Butler. The problem with the polyurethane mounts is if they are too close to a heat source the rubber will degrade and fail. Not a good choice for RA/HO exhaust manifolds or if your header tube is close to the motor mount.
Tim Corcoran
