Old 05-09-2024, 09:29 AM
Tom Pugh Tom Pugh is offline
Default Torque converters
I am running a T400with a 10"converter (2800 rpm stall) behind a mildy modified 455 in a '67 GTO. This is a street car with ac and will not be raced. What are you guys running for a trans cooler? I would like to install a frame mount like this; https://www.summitracing.com/parts/prm-6321?rrec=true
or something like this; [https://www.jegs.com/i/JEGS/555/6036...555%20Products
Old 05-09-2024, 10:16 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
If it is run in series with the stock radiator possibly. I prefer the stacked trans cooler for all my cars with higher stalls in them.
https://www.jegs.com/i/Derale/259/13402/10002/-1
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
The Following 2 Users Say Thank You to Jim Moshier For This Useful Post:
Old 05-09-2024, 10:31 AM
Verdoro 68's Avatar
Here’s a thread on how I did mine. It’s in sequence after the radiator cooler as Jim mentioned. It’s a stacked plate as well. I put it up front for better air flow, plus it also keeps it hidden.
https://forums.maxperformanceinc.com...7&postcount=21
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 05-09-2024, 01:02 PM
nice install...
The Following User Says Thank You to Tom Pugh For This Useful Post:
Old 05-10-2024, 10:54 AM
so, my next question is; how do I remove the condenser to access the area in front of it? My car is a factory air car and it has the panel installed between the radiator support and the front bumper so I can't go in through the bottom.
Old 05-10-2024, 04:33 PM
Verdoro 68's Avatar
I know ‘68 is completely different, but I didn’t have to remove the condenser to install mine. I dropped the valence, which I guess would be the bumper in your case, and pulled the right side grille for access. The lines run through the opening in the core support for the right side bumper bracket.
Ken
Old 05-11-2024, 09:20 AM
yeah, thats what I was worried about, having to disassemble the front end to get at it.
Old 05-11-2024, 02:49 PM
SRR's Avatar
SRR SRR is offline
Default Derale cooling pan
I just add one of these.
― Calvin Coolidge
