Old 03-20-2020, 11:56 PM
supersport#69 supersport#69 is offline
Default update pics
68 HO soon to be back to its factory black, but one more block run over each panel first .
ID:	534895   Click image for larger version
ID:	534896   Click image for larger version
ID:	534897   Click image for larger version
ID:	534898   Click image for larger version
The Following 2 Users Say Thank You to supersport#69 For This Useful Post:
Old 03-21-2020, 01:17 AM
dataway's Avatar
dataway dataway is offline
Excellent!
Hopefully by the end of the summer I will be ready to start screwing up my car with paint of some kind
Old 03-21-2020, 10:38 AM
It’s been slower moving than I wanted but still moving forward I guess. I want to repaint the bottom section of the red dash too before black is sprayed.
Old 03-27-2020, 01:13 AM
I need to buy a steel front valance to replace my cracked fiberglass one. Are they pretty much all reproduced in the same place with different brands on them?
Old 03-27-2020, 07:43 AM
dataway's Avatar
I'd like to know that answer to that also ... will need a steel one myself.
Old 03-28-2020, 06:01 AM
I'm sure there is one die. I have a couple orig 68s that will need work
Old 04-03-2020, 12:57 PM
Default More pics
Front bumper has some repairs to be dealt with I’ll post pics in s sec.
ID:	536239   Click image for larger version
ID:	536240   Click image for larger version
ID:	536241   Click image for larger version
ID:	536242   Click image for larger version
Old 04-03-2020, 01:02 PM
Default And more
The top is pretty good but passenger lower corner must have gotten a chunk hit out of it at some point.
The bumper is really the last repair before a final primer, etc before black.
ID:	536244   Click image for larger version
ID:	536245   Click image for larger version
ID:	536246   Click image for larger version
ID:	536247   Click image for larger version
Old 04-03-2020, 01:12 PM
Verdoro 68's Avatar
Presuming that's bondo on the bumper, make sure you get rid of all of it from the bumper. Sandblasting the bumper then repairing gouges and cracks with two part 3m epoxy is the way to go.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 04-03-2020, 01:41 PM
Yes! There’s about 3 inches of bondo there. That’s the worst part of it.
Looking at that bumper about how many hours would you figure to prep that bumper for primer?
Old 04-03-2020, 01:47 PM
Default Ok last ones today
I’m just excited to see it getting close.
ID:	536252   Click image for larger version
ID:	536253   Click image for larger version
ID:	536254   Click image for larger version
Old 04-03-2020, 03:44 PM
Verdoro 68's Avatar
Hard to say. I stripped and prepped mine for the body shop, but it didn't need nearly the repairs yours needs. I had a bunch of hairline cracks and some small chunks to repair. It was also covered with a thin coat of bondo or high built primer which made the cracks worse.
I will say the two part epoxy is great stuff, I haven't seen any sign of cracks in my bumper since it was painted 8 years ago. I'm not sure how much it's recommended to build it up though.
Old thread with some tips on repair: http://forums.maxperformanceinc.com/...d.php?t=689837
Search for some old posts by PaulAtFast in the Body Shop forum. He posted a lot of good info on how to work with these bumpers.
Ken
