Old 02-29-2024, 12:42 PM
Formulas Formulas is offline
A possible culprit can be to much oil laying in a blind bolt hole
bolt goes down hydro locks on the oil then in time enough oil passes by the threads un does percieved torque
reason i would put a possibility of this over bottomed out bolts is you torque a bolt down in a blind metal hole against incompleted threads or the end of threads what would change to release torque, possibly heat expansion i guess
fel pro gaskets ending in PT are permanent 1 time torque requirements, never hurts to retorque but should not be a instant fail time after time points to another problem
Old 02-29-2024, 01:42 PM
chiphead's Avatar
chiphead chiphead is offline
I always use 1016 gasket and ARP bolts with iron heads.
Have the heads been checked for cracks? I could see a head crack making you chase your tail.
Has the depth of the block's bolt holes been verified?
Is the torque wrench known to be good?
You have to ID where the gasket fails to prove the gasket seal is the issue. Where is the leak happening in the gasket?
Is it at the fire ring between cylinders, or between a coolant passage and the oil galley, or between the fire ring and a coolant passage?
The Following User Says Thank You to chiphead For This Useful Post:
Old 03-01-2024, 03:35 AM
lust4speed's Avatar
Look the old head gasket over closely and that should tell if water/oil is finding a path. The photo in Post 11 has a very definite and clean imprint and it's a safe assumption that it was not passing water or oil.
All my FelPro gaskets have the oblong hole and never had a problem. Think Sam's only problem was the cracked brass liner in one of the pushrod holes.
Mick Batson
The Following 2 Users Say Thank You to lust4speed For This Useful Post:
Old 03-01-2024, 06:46 AM
steve25 steve25 is online now
Whenever I gave hadtoo much oil in one or however many of the head bolt holeit always ends up boiling up and out of the area between the top of the head and the bottom of the head bolt.
There is no way for that area to be 100% sealed and holding pressure even when head bolt washers are used
, and the the few times that I have had a blown head gasket it was not from that symptom it was from head bolt holes that where not cleaned out enough to allow accurate torque readings
Old 03-01-2024, 09:49 AM
My hypothesis, and thats all it is, of oil laying in a blind hole has nothing to do with the head of the bolt area
simply put a head bolt in a blind hole and excessive amounts of oil cannot maintain the same space the oil has to leave the area before the bolt can be run down fully, this takes a bit of time like oil leaving a pumped up hydraulic lifter, if a person was to quickly torque a head bolt and move on the bolt might not be putting a clamp load on the head
only a possibility food for thought not a direct diagnosis and yes head bolt holes should be chased and clean with minimum lubrication to get the job done
Old 03-17-2024, 03:32 PM
tjs72lemans tjs72lemans is offline
The cometic gasket my engine builder put on my 400 build, said it doesn't need retorque when I asked after dyno run. 3000 miles now and still good.
Old 03-17-2024, 03:50 PM
Everything is 'good' until it fails.
It doesn't hurt to check, and not one person here has done that. Isn't it better to know for sure?
That's all I'm saying, check, and don't assume.
