Old 08-18-2019, 06:53 PM
BN's Avatar
BN BN is offline
Default Formula wheel hub fit question
Installing a formula wheel kit from Ames on 70 GTO. Does this gap look right? Can’t get it to tighten down any further. Suggestions?
Old 08-18-2019, 07:00 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Repro stuff is Junk. Get a GM hub
Old 08-19-2019, 10:29 AM
HWYSTR455's Avatar
I have the same problem, either live with it or get an OE one, as suggested.
Old 08-19-2019, 11:22 AM
BN's Avatar
BN BN is offline
Did a GM one solve the problem for you?
Old 08-19-2019, 11:37 AM
HWYSTR455's Avatar
I chose the 'live with it' route. I wanted a newly sprayed unit, and didn't want to have to paint an old one.
Old 08-19-2019, 01:06 PM
BN's Avatar
BN BN is offline
Called Ames tech support. Guy claims they've never had a complaint or problem. He said to take it off, make sure there's nothing on threads, use some light oil, and then reinstall. Went to auto parts store and borrowed wheel puller. Cleaned and checked everything, and of course....same result. While it was off I painted the inner collar thing that's visible and that hepled it not look so bad. Think I'll just live with it. Then I went to put wheel on and the allen head screws are obviously too big. Called Ames back and they said they're a tight fit but they'll fit. Well, as I said they're obviously TOO BIG. Tried to force them and they just went in a quarter turn, and are now stripped out. Waiting for a call back. Not sure what the deal is here. I've ordered many thousands of dollars of parts from Ames starting in the early eightees and never a single problem?
Old 08-19-2019, 01:10 PM
HWYSTR455's Avatar
At one point I heard the screws were metric, then changed over to SAE. One other person complained about having the wrong screws, most likely got a set of metric screws for an SAE hub or visa-versa.
There's several threads on it, could probably search it, but as before when I tried, it's not hitting on the key words I used, had trouble finding other threads.
Old 08-19-2019, 01:24 PM
BN's Avatar
BN BN is offline
I read it yesterday, but couldn’t find it again today. Told Ames about the post, but they didn’t listen.
Old 08-19-2019, 03:54 PM
Ram4king's Avatar
Send it back and buy a nice used original.
Old 08-19-2019, 06:56 PM
BN's Avatar
BN BN is offline
Yeah, I think you’re right.
Old 10-05-2019, 10:05 PM
racerboy's Avatar
racerboy racerboy is offline
This. I bought the hub and mounting bolts when I converted my ‘70 to power steering earlier this summer. The hub was tapped for SAE bolts, but they included Metric bolts in the package. I just retapped it to use the metric. I also have a similar cap. This repop stuff is crap sometimes.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 12-22-2019, 04:30 PM
BN's Avatar
BN BN is offline
Got an original and still a gap. Does anyone with an original wheel have this same problem. Maybe this is just how they all are?
Old 12-23-2019, 10:22 AM
HWYSTR455's Avatar
Here's mine, '71, OE non-tilt column, OE hub. So looks like it's 1/8" gap.
My tilt column, not OE to car, and aftermarket hub, are a larger gap for sure, and originally complained about it, which in my research was what drove my comments above. I posted on that in the 71-72 A body section.
Old 12-23-2019, 10:24 AM
HWYSTR455's Avatar
So looks like yours is double what my gap is.
Old 12-23-2019, 10:27 AM
HWYSTR455's Avatar
BN - Is that a tilt column? Tilt is going to naturally have more of a gap.
Old 12-23-2019, 10:34 AM
HWYSTR455's Avatar
Ames should have known AND heard of the problem, not sure what's going on there. They are aware of the issue regarding the screw sizes.
They are also aware of the gap problem, I know at least 3 people that have called about it, I being one of them. So I know they've at least heard about it.
There's no way to doctor it to fit tighter, period. It's a machined spline, and suspect they got the taper wrong when made, which makes sense with the whole metric/SAE issue.
Old 12-23-2019, 03:20 PM
BN's Avatar
BN BN is offline
No, standard column
Old 12-23-2019, 06:18 PM
BN's Avatar
BN BN is offline
Somewhere in these forums I read that originals had two different GM part numbers, but I can’t seem to find that post again. The original I have is stamped 6000 500. Maybe the other one is a different size?
