Old 02-20-2024, 04:59 PM
hdpontiac hdpontiac is offline
Default Edelbrock heads
I have a question on my edelbrock heads I'm wondering if the head cc can be changed from 72 cc which they are right now to around 82-85 cc without changing head is that something that a machine shop can do don't want to by new heads any help is appreciated.
Old 02-20-2024, 05:32 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
You can get to 75-76cc pretty easy just using a head gasket and opening up the chamber like the "notches" are in the block the gasket has.
Wanting to drop CR? Bigger dish?
Skip Fix
Old 02-20-2024, 05:54 PM
nas t eh nas t eh is offline
Pretty sure the better Pontiac head specialists convert/upgrade those 72 cc heads to a 85cc heart shaped combustion chamber all the time. The only problem is finding a shop that isn’t booked well into next year.
73 T/A 455, 4speed
Old 02-20-2024, 06:18 PM
steve25 steve25 is offline
So your saying your block is assembled Already?
The way Edelbrock got to the bigger chamber size they offer is the same route that the factory took, they machined the chambers deeper and used shorter valves.
In terms of making the best power and efficiency your better off with the 72 cc heads and dished pistons to get to your compression ratio you seek.
Also the deeper chamber heads can not be ported to the same level of peak air flow if your looking for such.
This effect is due to the reduction in short turn height in the ports of the bigger chambered heads.
If you can’t rework the pistons because the motor is together then I would first see if I could sell those heads and buy the larger chamber version.
Basically making a chambers perimeter bigger to gain volume will only server to increase the motors propensity to ping and knock.
This is a main reason why the deepening of the chambers is the way to go to drop your compression.
The Following 3 Users Say Thank You to steve25 For This Useful Post:
Old 02-21-2024, 09:10 PM
Schurkey Schurkey is offline
...and a thicker head gasket kills quench/squish, also leading to potentially more knock/ping.
The Following 2 Users Say Thank You to Schurkey For This Useful Post:
Old 02-22-2024, 07:59 AM
HWYSTR455's Avatar
Butler uses the bare 72cc heads when using their' CNC porting programs, they can do it IF the casting is a certain generation. Believe the first generation ones don't have enough meat for some of their' programs.
Call them and ask. They will accept customer's heads and CNC them. If you are unsure of the generation, they can make the determination at initial inspection.
There were some casting issues in the early runs of the first generation as well.
Recommendation: It costs the same to run just a chamber program as it does the base 315cfm program, so might as well do that.
They can do a 'modern' chamber too, but again, believe it's relevant to the generation.
Old 02-22-2024, 08:03 AM
HWYSTR455's Avatar
I hear a lot of talk about quench around here, but just to say, many other manufacturers' heads have no quench and run fine, with no det.
How do you measure quench on a hemi head?
Old 02-22-2024, 09:29 AM
PAUL K's Avatar
PAUL K PAUL K is online now
By it's octane tolerance.
Go fast, see Elvis!
Old 02-22-2024, 09:41 AM
HWYSTR455's Avatar
Then it's too late, the engine is already together so you can't change it.
Technically, you can measure quench on a hemi head, it's based off the dome of the piston used.
Point I was trying to make is that quench doesn't particularly make or break an engine, there's a lot of leeway. I believe too many just regurgitate what they've read. Many wedge head engines have horrible quench but still perform well. Without det.
Will quench make a difference in det or not when you're on the edge? Probably, but it's not going to help bring a 13:1 engine into pump gas territory.
Does quench help when trying to make peak power in a competition engine? Absolutely.
Can there be too much quench? Absolutely. Believe the 'generic' amount is .035, but that's just from memory, would have to check to be sure.
Old 02-22-2024, 10:11 AM
Stan Weiss's Avatar
Good morning Paul, When developing a new port. Do you look at the swirl curve and use that as part of of the processes?
Stan
Pontiac Pump Gas List
Old 02-22-2024, 10:19 AM
Stan Weiss's Avatar
Looking at Dr Blair's work. What you are looking for is squish velocity. Squish velocity is not only a function of piston to head clearance but also squish ratio (amount of quench area to bore area). In other words the larger my squish ratio the more piston to head clearance I can have to get the same squish velocity.
Stan
Old 02-22-2024, 10:30 AM
PAUL K's Avatar
Understood.... But you can have too much quench and too little quench.. The Hemi is an excellent head because of it's air flow capabilities but completely fails (sometimes) due to it's combustion chamber design.
The optimum quench area is ideal for a specific application. That should be the goal for any build.
"Many wedge head engines have horrible quench but still perform well" ..... I think it depends on what one's definition of "well" is or what "well" is compared to.
Go fast, see Elvis!
Old 02-22-2024, 10:45 AM
PAUL K's Avatar
Stan
Good morning Stan, I spent a lot of time twenty some years ago working with swirl, when it was the "thing to do". We found techniques that would improve swirl and everytime it was a win but also discovered when modifying an existing head we were limited to how much we could improve things. Same deal as "wet flow" it's more helpful when designing a cylinder head than developing a port.
Go fast, see Elvis!
Old 02-22-2024, 11:25 AM
Skip Fix's Avatar
swirl and dimples to stir up the boundry layer!
Skip Fix
Old 02-22-2024, 11:36 AM
PAUL K's Avatar
Lol!
Go fast, see Elvis!
Old 02-22-2024, 12:14 PM
Stan Weiss's Avatar
Skip,
No, dimples but a bur finish in places does seem to work.
Stan
Old 02-22-2024, 01:46 PM
Steve C. Steve C. is offline
Related, Jim McFarland published quite a bit in Circle Track magazine including tech material on dimpling.
https://www.motortrend.com/how-to/en...ixture-motion/
https://www.motortrend.com/how-to/en...y-faster-burn/
One of Jim's piston designs here:
https://i.postimg.cc/9MQf7Zxq/Jim-Mcfarland-piston.jpg
( Information provided in this post does not represent any endorsement. And unless specified it is not based on personal experience and is offered for general interest only )
Old information here:
The Following 2 Users Say Thank You to Steve C. For This Useful Post:
Old 02-22-2024, 05:01 PM
Skip Fix's Avatar
Jim and I discussed that several times. A lot of articles in Circle Track magazine. He was a Texas guy, Steve I think Austin. Some of his circle track motors in the articles were built by a shop near Dallas.
I told me he helped develop the Torker 1 for Pontiacs.
Skip Fix
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 02-22-2024, 05:21 PM
PAUL K's Avatar
I thought Jim was the guy in charge of the Torker project. I've always been curious as to why that manifold is usually and under performer but managed to pass Edelbrock's dyno evaluations.
Go fast, see Elvis!
Old 02-22-2024, 05:27 PM
Jim was native Texan and he earned a degree in mechanical engineering from the University of Texas. When I lived in Austin his home was not far from where I lived.
I collected a bunch of his published Circle Track tech material and spoke with him a few times. He was a true gentleman.
https://www.motortrend.com/news/jim-mcfarland-obit/
The Following 3 Users Say Thank You to Steve C. For This Useful Post:
