Old 03-03-2023, 01:43 PM
keepat's Avatar
keepat keepat is offline
Time to update the status of my 66 GTO. I installed a new gardener exhaust system. System fit and looks great.
Thanks Pat
ID:	608255   Click image for larger version
The Following User Says Thank You to keepat For This Useful Post:
  #102
Old 03-03-2023, 02:12 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Looks like it's going to be a quiet ride. Stunning car, great color.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
The Following User Says Thank You to OCMDGTO For This Useful Post:
  #103
Old 03-03-2023, 02:28 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Thanks Pat
Very nice! You cant beat the quality, fit & sound of a Gardner system.
The Following User Says Thank You to 428ho4spd For This Useful Post:
  #104
Old 03-03-2023, 06:29 PM
keepat's Avatar
I also replace the 25 year old tires
ID:	608269   Click image for larger version
  #105
Old 03-03-2023, 07:31 PM
428ho4spd's Avatar
Are those the new "bias look" radials?
  #106
Old 03-03-2023, 07:37 PM
keepat's Avatar
Fabricated a fire extinguisher mount that utilized existing holes in the seat track.
ID:	608276   Click image for larger version
ID:	608277   Click image for larger version
ID:	608278   Click image for larger version
ID:	608279   Click image for larger version
The Following 2 Users Say Thank You to keepat For This Useful Post:
  #107
Old 03-03-2023, 07:46 PM
Well done, very nice.
  #108
Old 03-03-2023, 08:41 PM
keepat's Avatar
Yes, and they ride great!
  #109
Old 03-03-2023, 08:50 PM
keepat's Avatar
Before installing the new exhaust I power washed and steam clean the bottom of the car to get 55+ years worth of grime off. Looks like a toy on the end of that big boat forklift;-)
Pat
ID:	608281   Click image for larger version
ID:	608282   Click image for larger version
  #110
Old 03-03-2023, 09:23 PM
gokitty gokitty is offline
The 67s had the most bling of all the GTOs. Personally, I think the stainless rocker panels on your 66 are attractive. The 66s and 67s had the same basic body lines. I can see a 66 with 67 front grill and the 67 stainless rockers as combining the best of both years!
  #111
Old 03-07-2023, 09:32 PM
keepat's Avatar
Last winter project was replacing the original leaking heater core. Hardest part of the job is the access to outer bolt holding the heater box assembly to the firewall. The replacement heater core is similar in size but thinner. Slightly bending the original clips hold it in place nicely.
ID:	608534   Click image for larger version
ID:	608535   Click image for larger version
ID:	608536   Click image for larger version
ID:	608537   Click image for larger version
  #112
Old 03-07-2023, 09:37 PM
keepat's Avatar
Install went smoothly, except for same battle of getting that outer nut installed.
Pat
ID:	608539   Click image for larger version
ID:	608540   Click image for larger version
ID:	608541   Click image for larger version
  #113
Old 03-08-2023, 11:54 AM
ZeGermanHam's Avatar
Nice work! A leaking heater core is what causes many peoples' passenger front floorboard to rot out, mine included. Surprised you didn't remove the seat during the processes to minimize the amount of contortion needed to R&R!
1998 BMW 328is (track rat)
  #114
Old 03-08-2023, 04:30 PM
keepat's Avatar
With the seat slid back I had plenty of room as most of the work was through the glove box opening.
Pat
  #115
Old 03-30-2023, 12:22 PM
Hey Pat, I've got a question for you... Assuming your hood latch is original and hasn't been altered (painted), what is the finish of it on your car? I need a new hood latch kit for my '66, and Ames sells one that is plated in silver cad, whereas OPGI sells one that is plated in gold cad. I'm trying to figure out which finish is correct. Thanks.
  #116
Old 03-30-2023, 12:29 PM
imposter's Avatar
imposter imposter is offline
what size tires did you use
  #117
Old 03-30-2023, 12:47 PM
keepat's Avatar
The latch is original and it is gold cad but note the latch stop mount is silver cad. See attached picture.
Pat
  #118
Old 03-30-2023, 12:48 PM
keepat's Avatar
FR70-14
Pat
  #119
Old 03-30-2023, 01:19 PM
Pat
Thanks! Much appreciated.
  #120
Old 03-30-2023, 04:18 PM
keepat's Avatar
Glad I could help and good luck with your project!
Pat
