Old 09-10-2019, 06:18 PM
cold coffee cold coffee is offline
Default Need some help with pushrod length, lifter preload
Hi, this is my thread from 2 years ago:
http://forums.maxperformanceinc.com/...d.php?t=803702
I'm just now putting the engine together, and as it's my first I'm a bit confused about these two things. I've read lots of threads here and watched lots of you tube videos and I think I almost have it.
https://www.youtube.com/watch?v=76wbtu9l09A
Measuring pushrod length the way this guy does, I come up with 9.1857". This is with the non adjustable rocker snug and the plunger on the lifter all the way up.
Pattern on the valve tip is dead center.
I have these lifters: https://www.summitracing.com/parts/rhl-9518l/overview/
I'm not sure what I should add for preload.
This says the plungers should be down between1/16 and 1/8th from the top.
http://www.rhoadslifters.com/Pages/Installation.html
So do I take that pushrod length and add an extra 1/16 to 1/8 to it?
Very new to this, please be gentle.
Edit forgot engine specs.
455
6x heads w/ new springs and valves
crower 60919 cam
Old 09-10-2019, 07:44 PM
Formulas Formulas is offline
You got 7/16 fine thread studs ? Which are 20 threads per inch if you go 1 full turn of preload you in effect have used a 20th of an inch so divide a inch x 20 in decimal that's preload distance
.050
Old 09-10-2019, 09:48 PM
.050
they are whatever stock is.
Old 09-11-2019, 06:02 AM
First some question need to be asked here.
Have the heads been milled and or the block?
Has a valve job been done to the heads?
Milling the heads or the deck of the block will make for the need of longer then the stock 9.130" push Rods as will applying a valve job to the head since that sinks the valves deeper.
Stock Pontiac rocker studs are 5/16" fine thread on the top and the rocker ball is non adjustable.
You have two problems here , 1 the factory non adjustable valve train and 2 the fact that the .470" lift of that Cam stands a good chance of snapping off that small stock 5/16" rocker stud top section due to the added leverage of that .470" lift!
Ask me how I know this!!
The start of the fix for both is to install 7/16" top and bottom size studs with a set of the needed size poly locks for adjustability.
Old 09-11-2019, 12:20 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Actually, stock studs are 3/8" on top and that equates to .042" movement for 1 turn. Like Steve said, best to get rid of the bottle neck studs and get straight 7/16" studs.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 09-11-2019, 05:56 PM
tc's Avatar
tc tc is offline
Yes you do add to the pushrod length. You probably are not going to order custom made pushrods, so you will purchase whatever length increments they offer, .050 or .100 length differences. Go with a shorter length if your dimension falls between two offered lengths. I would only add 1/16.
What did you use for a lifter when checking the pushrod length? Are you sure the lifter plunger did not move down? Is the checking lifter plunger height the same as the lifters you will use in the running engine?
Old 09-11-2019, 11:21 PM
Schurkey Schurkey is offline
.050
Not exactly. Moving the adjuster nut .050 moves the lifter plunger more than that because of rocker ratio.
Milling the block deck or the head deck may require SHORTER pushrods, depending on the amount of travel in the lifter plunger, and the amount of material removed.
Sinking the valves may require SHORTER pushrods. In the old days, the amount of material taken from the valve face (and seat) was compensated for by shaving material off the valve tip. I don't suppose folks do that any more, in part because the valve tip hardening layer may not be thick enough.
Old 09-12-2019, 05:49 AM
Sorry, I always make that mistake , and I know better!
I need to review my post before posting!
Old 09-12-2019, 07:20 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
I'm pretty sure all of that was done because of the crimp lock factory nuts that had a fixed height. Anyone doing anything these days will first put on the thicker studs and polly locks. I bet this is the real reason you don't see such things being done now.
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 09-12-2019, 08:13 AM
Use this method:
https://www.youtube.com/watch?v=o5is9BsH5OU
No need to take any lifter plunger movement into account.
This method determines the correct valvetrain geometry, and you calculate using half the lobe lift of the cam and rockers that are installed.
Screw that valve tip marking method, which usually has you changing the pushrods after a few 1000 miles.
Old 09-12-2019, 08:45 AM
beertracker's Avatar
beertracker beertracker is offline
take a look here; https://www.lunatipower.com/how-to-v...train-geometry
