Old 04-17-2024, 11:30 PM
I concur!
Old 04-18-2024, 12:44 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
221 or 260 in the Meteor? (Sorry if you already told me and I forgot)
  #443
Old 04-18-2024, 12:58 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Decide to buy a Digital angle gauge to try and check my pinion angles, Already had adjustable uppers, but had never bothered to check it.
Had a 4 post hoist at work, but had to wait till retied and do it at home. LOL. Crawling around on floor I found that trans was down 2.1 *
and rear was pointed down 3.5*. OOPS. adjusted to up 2.1* and found I was able to move axle housing a touch side to side with adjustable
uppers. Tires were hitting exhaust, adjusted to center the diff and road tested. All good. Now onto the next thing I have been putting off for years, LOL.
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
  #444
Old 04-18-2024, 06:25 AM
67drake's Avatar
67drake 67drake is offline
Well, I had always thought it was a 221 based on the casting codes. After I pulled the engine and inspected it, I found it to be a 260! I brought this issue with the codes up over on a Ford website, and the best explanation we can come up with is that it’s possibly a service replacement block.
13.95 @ 102.1 on street tires @ 4055lbs.
  #445
Old 04-18-2024, 10:10 PM
400 4spd.'s Avatar
We recently replaced a customer's exhaust system ('69 GTO) with a Gardner system (awesome quality and fit), and I bought the 2 1/2" system we removed. As time has allowed the past couple of days, I now have it under my '72 Grand Prix.
Next week I'm picking up a built '67 428 from another customer. Hoping it ends up in my '67 GTO. My original WT can go to the next owner when the time comes.
The Following User Says Thank You to 400 4spd. For This Useful Post:
  #446
Old 04-19-2024, 12:14 AM
MUSLCAH MUSLCAH is offline
Getting the 64 GP out of storage ...Saturday....Then my 67 GTO next weekend.
The Following User Says Thank You to MUSLCAH For This Useful Post:
  #447
Old 04-19-2024, 02:41 AM
65 Lamnas's Avatar
Compared the pics of my block from 10 months ago to vs today.
ID:	632298   Click image for larger version
ID:	632299   Click image for larger version
ID:	632300   Click image for larger version
The Following User Says Thank You to 65 Lamnas For This Useful Post:
  #448
Old 04-20-2024, 12:39 AM
Well... I didn't actually do this today, I had a shop do it. Both exhaust manifold gaskets needed replacing on the 455HO in the 'Bandit' Suburban, so I bought a pair of Remflex gaskets and had them installed. It's a nasty job even on a lift. I have to admit to feeling too old to tackle it from a creeper.
I can't complain about the gaskets- the engine was built in '93- 31 years and lord knows how many miles ago! I've put 50,000 miles on it without ever needing to get into the engine.
What I did do on my Pontiac today was continue machining stuff to convert the lakester's broken four cylinder hemi Pontiac to a two-cylinder. Rather than source a smaller blower, I'll keep the huge 14-71, but underdrive it a bunch more (about 19% of crank speed) . This requires a 2-stage belt drive, so I'm almost finished machining a jackshaft arrangement. Keeping with the low-budget approach, and using spare parts, I'll only need to buy a couple of belts.
The Following 2 Users Say Thank You to Jack Gifford For This Useful Post:
  #449
Old 04-20-2024, 02:20 PM
BILL BOWMAN1's Avatar
Relocated bottom shock mount so I can put a bigger tire on.
The Following 2 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
  #450
Old 04-20-2024, 04:21 PM
Now I hopefully will be able to shoehorn these custom 8 lugs with 255-70-15’s.
  #451
Old 04-21-2024, 07:23 PM
Verdoro 68's Avatar
Got up at the crack of dawn and headed over to a show in Benicia, CA. Pretty good showing of Pontiacs. Every time I go to one of these big shows where you're locked in all day, I'm reminded me why I like the smaller casual cruise ins better.
ID:	632449   Click image for larger version
ID:	632450   Click image for larger version
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
The Following 5 Users Say Thank You to Verdoro 68 For This Useful Post:
  #452
Old 04-22-2024, 07:53 PM
Quick test fit on one side.. still room to spare!
  #453
Old 04-22-2024, 11:29 PM
Talking Did the unthinkable today…..
Began cloning the Le Mans into a GTO.
The Horror…..
  #454
Old 04-28-2024, 05:20 PM
FirebirdHank's Avatar
Finally got around to getting the Firebird out of the corner of the garage. First thing was new tires. Before even starting it I removed the wheels and took them to the tire shop for a brand new set of BFG TA Radials. On the way to drop them off I realized that a tire on the truck was starting to separate at the plys. So I got two sets of new tires at once. Anyway, Friday I picked up the van with the Firebird tires in the back and had the 'Bird off of the jack-stands and ready for a test drive. Fired right up and all seems good. Yesterday was the day to shift everything around in the garage to summer mode. I think I'm officially ready for summer.
  #455
Old 04-28-2024, 05:45 PM
Verdoro 68's Avatar
Pulled the 8.2 and have been prepping the new rear end for install. Annoyed that Moser left out the axle seals, vent tube and backing plate t-bolts for as much as this thing cost. Debating whether I paint the aluminum cover black or not.
ID:	632798   Click image for larger version
ID:	632799   Click image for larger version
Ken
  #456
Old 04-28-2024, 05:57 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
got my windows tinted yesterday w/ ceramic film. Clear on the windshield and the lightest available for the remaining. it's uv blocking which should help reduce interior temps, too.
ID:	632803   Click image for larger version
ID:	632804   Click image for larger version
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
The Following 2 Users Say Thank You to Tuske427 For This Useful Post:
  #457
Old 04-28-2024, 09:34 PM
67drake's Avatar
Nothing on my Pontiacs, but I did break my Mercury engine and cam in today. NOW, I can focus on my Pontiacs.
Man I was nervous about that HFT break in, but seems OK. It fired instantly, and runs great. Time will tell.
Hopefully my 16 year old learned a few things, he’s a gear head, just like my older boys.
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #458
Old 04-29-2024, 12:03 AM
65 Lamnas's Avatar
The H/L bezels on the '65 look to be original, and were badly pitted. Found a decent original pair that only has minor pits. Touched up the black paint, and put on new gaskets, which were a bitch to get on and stay, but got 'er done. After aiming the headlights, I put 'em on......they look OK.
ID:	632829   Click image for larger version
ID:	632830   Click image for larger version
The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post:
  #459
Old 04-29-2024, 12:45 PM
1st chi-chi cruise of the year with the unprecedented weather I don't believe she has ever been on the road in April!
Only a few diehards and tons of ricers out but still nice to get out of the house.
The Following 2 Users Say Thank You to kingbuzzo For This Useful Post:
  #460
Old 04-29-2024, 12:51 PM
Not a Pontiac.. but. Cleaned this up yesterday and put it up for sale.
1974 Formula 400 - Ram Air automatic
