Old 12-20-2018, 08:47 AM
Squidward's Avatar
Originally Posted by HALFWAY View Post
"ive used 2 of the cardone reman pumps & they worked great, they are not supplied with the valve so it says you have to reuse yours. good oppotunity to clean it out & start fresh. "
What is this valve you speak of?
I need to get a replacement pump for a 65 and have not read anything about reusing a valve.
Sent from my XT1080 using Tapatalk
It is the pressure regulator valve. It controls the outlet pressure of the pump, and is actually integrated as part of the outlet fitting.
I've heard that later model boxes (Jeep, 2nd gen, etc.) need some extra pressure to perform ideally. Maybe that would be a reason to reuse the pressure valve from an ideally operating system. You could possibly avoid some of the rebuild roulette.
Old 12-20-2018, 09:03 AM
HWYSTR455's Avatar
Yeah, it's not just psi, it's flow volume too. One problem is that not all valves are compatible with all pumps. I think Schurkey has posted the valve types/differences, as I recall there's 6 types.
Wish someone made a simple bracket to use a type II in place of a type I pump.
Old 12-20-2018, 09:46 AM
HALFWAY's Avatar
HALFWAY HALFWAY is offline
I am getting the complete pump and reservoir, would the valve be included in this case?
I have a 65 block in a 64 LeMans, the 64 pump will not work with the 65 power steering bracket.
I was hoping this would be a plug and play replacement.
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
Old 12-20-2018, 09:51 AM
78w72 78w72 is offline
its in the big nut on the bottom of the pump that the pressure hose connects to, it has a orifice in it that regulates the fluid. most reman pumps dont come with it & require you to re use the one from the original pump.
Old 12-20-2018, 09:58 AM
HALFWAY's Avatar
Thanks, I understand now.
Now I just hope the valve from the 64 pump will fit/work with the 65 pump.
Old 02-16-2020, 06:01 PM
4dblnkldude's Avatar
Reviving this thread because I was doing this today. The pulley on my 81 TA was slightly bent so I had another perfect pulley on another pump. I removed the pump from the car and both pulleys. I went to put on the good pulley and of course the threads in the middle of the shaft are stripped. Any suggestions?
Old 02-16-2020, 06:42 PM
mgarblik mgarblik is offline
By 1981, you may have the metric pump. It's possible the threads in the shaft are metric. If they are not too badly damaged, you may be able to re-tap them and then use a proper bolt to push the pulley on. Need to determine what the threads are first.
Old 02-16-2020, 08:49 PM
HWYSTR455's Avatar
Or switch to a earlier pump.
What bolt goes into the snout of the water pump?
Old 02-16-2020, 10:15 PM
The engine is from a 77 trans am. My gut is telling me it is not the original pump. I'll have to clean the threads up a bit and see what I can do. Highway you mean the bolt on the PS pump? You guys think the reservior would crush in a bottle jack press if I can position it nicely?
Old 02-17-2020, 08:17 AM
dataway's Avatar
dataway dataway is offline
I rebuilt my OEM pump with a kit ... seemed pretty straight forward. Surprised more people don't do that.
Old 02-17-2020, 10:58 AM
HWYSTR455's Avatar
My bad, I got a couple threads confused, ignore that comment(s)!
