EFI Tech All things EFI and making classics modern!
Old 12-03-2023, 10:13 AM
HWYSTR455's Avatar
Just to say, no matter what you do, you have to physically check inductive delay, it's not reliant to only the pick type.
Digital rising denotes when the pickup is at the beginning of a 'window', digital falling is when it's at the end.
EDIT/Correction - I have this backwards, it should read: 'Digital falling denotes when the pickup is at the beginning of a 'window', digital rising is when it's at the end.'
Image & Reference source:
https://forums.holley.com/forum/holl...igital-falling
For the most part, a crank trigger should be digital falling.
Additional reference source:
https://forums.holley.com/forum/holl...-Sensor-Setup=
Old 12-03-2023, 10:21 AM
HWYSTR455's Avatar
"When the sensor sees the edge of an “opening” or a “gap”, this triggers the sensor in a “Falling” manner.
When the sensor sees the first edge of the material or tooth, this trigger the sensor in a “Rising” manner."
Old 12-03-2023, 10:27 AM
HWYSTR455's Avatar
In the example, for a hall effect crank trigger, inductive delay is set to '1'.
But that's an example, and you need to physically check.
Old 12-03-2023, 10:41 AM
HWYSTR455's Avatar
There is no selection for 'Hall Effect' sensor, 'Magnetic' is used.
Old 12-03-2023, 12:20 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Thanks for the replies..
My Holley V5 won't allow me to access the Dwell window unless it's connected it seems, lame.
I have a Summit Ignition box so while I'll have the tuner run the show for now I'm going to do the Joe Simpson classes and make sure I'm on top of all this after this engine is completed.
Sounds like...
Crank = Type 12-1, Sensor Magnetic, Inductive 1usec
Cam = Dual Sync/ Custom? - Digital Falling
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 12-03-2023, 04:34 PM
HWYSTR455's Avatar
You should really upgrade to V6 Build 400, you may not get support if you call Holley, first then they will tell you is to upgrade. It also requires a firmware update I believe.
The 'dwell' setting is only available with certain ignition options, and custom. It's under System Parameters > Ignition Parameters > Custom , then it depends on the type of crank sensor option you select.
That image I posted before is offline and shows the dwell option. Change the type of crank sensor option and it will probably appear.
Old 12-03-2023, 04:38 PM
HWYSTR455's Avatar
There are many bug fixes in V6, and feature updates. Surprised your tuner didn't recommend it.
Here's the V6 revision history:
https://documents.holley.com/techlib...evisionlog.pdf
It's pages long.
Old 01-05-2024, 01:55 AM
GOAT8U2's Avatar
Scanned, CAD and prototype bracket made.
I hope to have the final piece next week and on the engine by the end.
Goal is to have the engine back on the dyno, all steps taken to ensure the tune sees on the money timing and then how to replicate for future Ponti EFI enthusiasts.
My bracket will be available in case Holley doesn't make a specific kit.
Old 01-16-2024, 02:47 PM
GOAT8U2's Avatar
Ok brackets are on, the L bracket needs to be redone smaller as the stock crank pulley diameter barely touches the L bracket for hall sensor.
Getting closer, this looks like it'll work, I'll have a complete custom kit for us.....
Custom Ponti timing cover bracket
Custom Hall Sensor L bracket
Shims for bottom of L bracket for perfect centering of Hall sensor
Water pump and alternator spacers due to 12-1 wheel thickness pushing out crank pulley.
Watch, Holley makes this kit over the Summer after they see there's a Ponti market. LOL
Pictures coming soon after we get it completed, probably Jan 22nd week.
The Following User Says Thank You to GOAT8U2 For This Useful Post:
Old 01-23-2024, 12:31 PM
HWYSTR455's Avatar
I'd really like to see the pics when you get a chance, I may go that route on my other build.
Old 01-23-2024, 12:38 PM
GOAT8U2's Avatar
We're getting closer, needed many tweaks to the brackets for those of us with the stock crank pulley diameter.
When its done it'll be a nice addition to our community and hopefully cover a bunch of us. I'll evetually need info on if 68-69 timing covers are the only ones that have bracket holes in this location etc. I think there's a good chance only the main bracket holes would need to tweak for different blocks of the holes aren't in the same location.
I'll have details soon, pics and hopefully dyno data to help future installs.
The Following 2 Users Say Thank You to GOAT8U2 For This Useful Post:
Old 01-24-2024, 01:16 AM
R 70 Judge's Avatar
I think the timing covers are the same from 69-79. Who would’ve thought that you using a different balancer and pulleys than me would be such a difference. I use a Moroso 3 bolt mandrel to drive my power steering and alternator. My set up is pretty common for a race car setup, hence why I didn’t have the pulley issue.
It’s great that you are making something that fits a wider range of applications!
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 01-24-2024, 09:33 AM
HWYSTR455's Avatar
Yeah, like I mentioned in another thread, the pulley setup is a deal-breaker for me. I have like $3500 in a Billet Specialties serpentine kit. But even folks with AC are going to shy away.
Being able to use OE pulleys will make it a more fluid choice.
That's why I got the setup from the guy I was talking about in the other thread, the wheel mounts on the back of an SFI balancer, same brand I'm currently using. The wheel needs to be perfectly centered, and balanced, to not impact balancer function.
Of course, technically, it invalidates the SFI rating, but doubt anyone would take a hit on it in a tech inspection.
The 80-81 301 timing cover has no timing marks, the whole standoff on the cover isn't there. That gives a person plenty of room to mount a pickup bracket in the OE location of the timing marks, and that is what I had planned to do when I was building the boosted engine. And they are available new.
ID:	627085   Click image for larger version
Old 01-24-2024, 04:47 PM
GOAT8U2's Avatar
Looking like I'll be able to offer a pretty complete bolt on 12-1 kit, I'll post back soon but I'll leave the sensor up to the customer, also I'm not really looking to be a retailer but it's looking like that's the case to pull this off.
4 bolt Pontiac 12-1 trigger wheel (7.25" diameter)
Pontiac mounting brackets
Spacers for water pump and alternator
My GTO used to be ac, those people probably won't go this route anyways but if so they just make an ac pulley spacer, done.
Old 04-07-2024, 03:50 PM
darbikrash darbikrash is online now
I recently converted a dual sync setup to a dedicated crank trigger. I thought I'd post up a few pics on my setup.
I am using the dual sync now for cam signal only, with a COP/CNP 8 coil setup on the Pontiac V8.
ATI does sell a flying magnet shell with embedded magnets (pictured below), and as I already had the ATI balancer it was easy to upgrade. This approach does not change the pulley position, nor requires drilling any holes in an SFI balancer.
Note this is for a 3 hole serpentine pulley setup, not the Pontiac 4 hole V belt pulley.
I used 4 magnets with a 50 deg. reference angle, but you can also order the ATI shell with up to 12 magnets if you wish, but I don't see the benefit- having one magnet at TDC for each cylinder is all you really need for a V8, and having the single pulse cam signal from the dual sync means you can use full sequential injection.
The crank sensor is a Hall effect.
The brackets I machined mount to and replace the fuel pump block off plate, and allow adjustment of the sensor in 3 axes. I haven't had a chance to anodize the parts yet, but it's coming.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
The Following User Says Thank You to darbikrash For This Useful Post:
Old 04-07-2024, 04:30 PM
GOAT8U2's Avatar
I have a kit already done, bolt on 12-1 trigger wheel, timing cover bracket and L bracket for sensor. I'm waiting for my friend to send me the brackets for the first kits sale.
Old 04-09-2024, 10:53 PM
R 70 Judge's Avatar
Great looking setup! I’ve suggested people use the ATI shell with integrated magnets if they want to retain an original style pulley set-up.
The set-up on my car works great. Like you I’m running an CNP set-up and I’m only using the dual sync for the cam signal.
James
1970 Trans Am
  #38
Old 04-09-2024, 10:54 PM
R 70 Judge's Avatar
I didn’t realize you were going to make the wheels as well. Looks great !
James
1970 Trans Am
  #39
Old 04-10-2024, 07:49 AM
EFI Pontiac EFI Pontiac is offline
Send a message via ICQ to EFI Pontiac
Default 12-1 Crank Sensor Kits
Will your kit work with a March Serpentine kit with the Power Steering Pump ? Will it work with an Innovators West Balancer ?
  #40
Old 04-10-2024, 10:42 AM
GOAT8U2's Avatar
12-1 wheel is 7.25", stock bolt pattern with plenty of holes option spacing and center circumference opening based on a real Pontiac balancer.
Brackets will bolt onto the timing cover and clear under the large stock crank pulley.
It wasn't created to make money, that's why the other company's said they didn't offer it for us, we wouldn't buy it. So since I wanted to run it, they challenged me to show them that others can do what they do and offer it at a similar price as the Ford and Chevy kits even at 25x less production numbers.
Not sure yet what is different about the March pulleys but it will fit any Pontiac balancer unless something was changed on it. Like any new kit, customized factors can change the fit.
