Old 02-26-2017, 01:59 AM
Marv Marv is offline
Does anyone have info about wheel well space in a 1964 Bonneville? I was looking at 15x7in or 17x7in American Racing 200S "Daisy" wheels but they only come in 4in backspace. Does anyone know if this will fit if i run a 205/60 (15in) or 215/45 (17in)?
Further complicating the issue is my car rides on air suspension and i dont want the car resting on the wheels (which will push on the bodywork) when it is aired out. Narrower tyres should help this but i am concerned the outer edge of the wheel will contact the inner face of the guard/fender
Currently i have 15in Cragar S/S with 205/60 tyres. I dont mind altering the rolling diameter (by running smaller tyres) as i will have to run a speedo adapter to suit the TH400 i have installed to replace the dead Super-Hydro 4spd.
  #122
Old 02-26-2017, 08:55 AM
t walgamuth's Avatar
t walgamuth t walgamuth is offline
You shouldn't need a speedo adapter. Both trannies are 1 to 1 in top gear.
Autocrossing, diesel loving, tri-power loving grandpa Architect
  #123
Old 06-20-2017, 02:58 PM
66 Wagon's Avatar
66 Wagon 66 Wagon is offline
What do you say about 15x7 wheels with 4,25 backspace and +6 offset
or 15x7 with 4,5 backspace and 0 offset?
Would any of them fit a 66 Bonneville with fenders and if so, what size of tires would be best?
http://forums.maxperformanceinc.com/forums/image.php?type=sigpic&userid=169941&dateline=15132  72224
66 Bonneville 4-door Hardtop - Sold - But it has its own thread here
66 Bonneville Wagon - Sold
63 Grand Prix - Sold
  #124
Old 06-20-2017, 03:28 PM
I don't know from experience but my guess is they will work. Don't take my word for it though!
  #125
Old 06-20-2017, 05:56 PM
63gpman's Avatar
63gpman 63gpman is offline
4.25" backspacing should work depending on the width of the tire and may still be tight. Don't think the 4" will work with skirts.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
  #126
Old 06-21-2017, 02:43 PM
66 Wagon's Avatar
What's the backspacing on a factory 14x6 wheel?
  #127
Old 06-26-2017, 10:05 PM
Nickv's Avatar
Nickv Nickv is offline
I Have a 67 GP with 15x6 Rally's and 225/70-15 tires. Plenty of of clearance in the back on both sides. I just ordered 17x8 Cragar 69 wheels with 4.50 backspacing and 0mm offset. Will be using 225/60-17 tires. Same height and width. Should be no issue from what I can tell.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecarsgalore.com
www.nikivee.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger ScatPack 392, 6 speed
2017 Ford Explorer AWD
  #128
Old 09-01-2017, 08:49 PM
Jeffs64Cat Jeffs64Cat is offline
I hav a chance to get some nice wheels to put on my 64 Catalina but after reading this sticky I'm more confused then when I started. The wheels are 15 x 8 with a 4" back spacing. If they will work what tires are recommended
Jeff
  #129
Old 03-14-2018, 08:47 PM
70ra455's Avatar
70ra455 70ra455 is offline
I'm ready to buy tires right now and am more confused than ever. Someone, my mind is slipping and I can't find the info, posted pics of his '66 (65?) Bonnie with 235/75/15 with 8 lugs and he says they fit wonderfully with no issue (with skirts). But from what I'm seeing here they shouldn't fit (or am I mistaken? I'm usually great with numbers too! lol)???
Anyway, I just want to get a nice wheel for the 15" steelies with poverty caps 15x6 wheels and can't figure out what will fit and look good. Will 235/75 fit? Or should I go to 225/75? 235 or 225 with 70%??
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
  #130
Old 04-07-2018, 10:10 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
I am looking to buy new 15" BOP 8 lugs, and some bigger tires, for my 65 Catalina. I am currently experimenting ... I put a 235-70-15 on a stock steel Pontiac wheel. There is about an inch of clearance between the tire and the 1/4, and a bit over 2" between the tire and the frame. These tires are 9.3 wide, and roughly 28 tall.
Hope this helps some.
  #131
Old 04-08-2018, 08:29 PM
70ra455's Avatar
I tried to get 235/75/15 on my car and they weren't even close to fitting (with skirts). I was thinking that because I have 4 wheel disc brakes added that if I remember correctly the brackets from Scarebird push out the wheels a little bit over 1/2" and that may be causing my problems.
I went with 215/75/15 ... and am wondering if I shouldn't use 215/70/15 instead ... I'll ride around for awhile with what I have and see how I like the look, feel, and handling.
  #132
Old 08-24-2019, 05:31 PM
Stuart's Avatar
Stuart Stuart is offline
From a separate post made on 8-24-19:
Originally Posted by Mrp613 View Post
Just an FYI a 28/10.5/15 will mount on a 66 Catalina using an eight inch steel Chevy truck wheel. Just rolled the fender lip up a little. Didn’t have to unbolt the shocks to get them on just let the suspension sag to full drop.
  #133
Old 10-20-2019, 05:00 PM
TransAm400 TransAm400 is online now
I’m running 15x8 8 lugs with a 275/60/15 drag radial. Good clearance on both sides. 64 Catalina
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
The Following User Says Thank You to TransAm400 For This Useful Post:
  #134
Old 02-09-2021, 10:12 PM
GruntedCatalina GruntedCatalina is offline
man this looks amazing
  #135
Old 02-19-2021, 09:59 PM
balmfort's Avatar
balmfort balmfort is offline
What back spacing on those wheels?
Phil
'63 Grand Prix / 389 Tri-power
  #136
Old 08-26-2021, 01:20 PM
mjm421's Avatar
mjm421 mjm421 is offline
275/60/15 on a 15x7 wheel with 4.25 back space.
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
  #137
Old 07-27-2023, 02:32 AM
Zooguy Zooguy is offline
**Revival**
My 1966 STARCHY has some 15x14" wheels & 470/43/15 tires
The tires dont have lots of room but are 31"x18.5”-15” and tucked in nicely
ID:	616783   Click image for larger version
ID:	616784   Click image for larger version
  #138
Old 07-27-2023, 07:00 AM
Stuart's Avatar
^ Yes, but it also appears your car has some serious wheel tubs.
The Following User Says Thank You to Stuart For This Useful Post:
  #139
Old 07-27-2023, 09:14 AM
misterp266's Avatar
misterp266 misterp266 is online now
Originally Posted by Zooguy View Post
**Revival**
Looks good Troy. You gonna put dog dish caps on those wheels?
" Darksiders Rule "
  #140
Old 07-28-2023, 03:17 AM
Dont have the caps on yet but these are the ones
