Tranny Cooler location
Anyone else on here mount there tranny cooler under the car? I have mine 1.5 inch off the floor and it has a fan. Anyone run a street car like like this?? No room in the front of the car.
I hope you got a shield to protect it from debris that will get kicked up into it from the road...
My Half AN Injun..... |
Some installations I have seen place them as far back as where a stock fuel tank would sit.
They make a 2 row and about 24" to go under the rad support or down the frame rail if you don't have room.
1972 Grand Prix |
1967 GTO rad support with tranny cooler...mounted it...cut a 7" diameter hole, made a 'grill' out of an old GTO grill.....also included pics of the radiator/fan.....derale shroug with dual fans and a Griffin 2 row aluminum radiator......runs at thermostat temp....
Nice Eric, my problem is I have a turbo on the r/front and a 36 x6 inch intercooler in front of the radiator. I am hoping it will stay cool enough.
The trans cooler has a fan and a cage around it so debris should not be a problem. I guess I will find out! |
My car sits way low in the front, I would mill that down in no time, LOL
What model car do you have? I'd like to see the turbo set up....I have been told that a tranny cooler can be mounted 'almost anywhere...
It is a 70 Lemans. Garage built by me. I'll post some engine picks for you later, I have a portion of the build on here I had brought over from PZ. I love your car by the way. Saw the magazine with it too.
Thanks, We aren't too far apart. I would like to see your build sometime!!! E
S+K is doing another track rental at Atco soon, do you run your car at the track?? |
I mounted mine in the valance opening, used the grill bracket mounting tabs, using brackets from the cooler manufacturer. Stack plate, think it's a 13x7. On the other side, did a cooler for power steering.
It would take a pretty healthy rock shot for it to make one leak, but am still considering some screen in front of them. But there's plenty of room up there. .
I have one back by the rear axle. With a fan of course.
looks like you have another cooler in front of the radiator as well i was thinking of moving my cooler to free up some air space to bring the heat down just have no time to do it myself anymore
Here is why I have no room up front, This is without my radiator.
Eric here is the engine compartment too. |
I have no idea why the photos turn sometimes!!
