Old 08-22-2015, 07:14 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Originally Posted by 61 389-348 View Post
The lens is the reason the beam is sharp and precise. The reflector is the reason that the beam is bright .... well most of it.
Good to know. I can't say enough good things about both on my Cibie.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
  #82
Old 08-22-2015, 08:29 PM
64catalina 64catalina is offline
Default Brighter Lights
After reading this thread I had the occasion to be out in the country at night.
I guess I really don't do it that often because my lights suck.
I was wondering with the relays directing the current to the headlights, what about the rest of the lights that go on with the head lights ? Brake lights, dash..
Sorry i did not look for my wiring diagram yet.
I'm using LED 1157's in turn signals and brake lights.
Old 08-23-2015, 12:13 AM
61 389-348's Avatar
61 389-348 61 389-348 is offline
I just got back from gym, dinner, grocery, etc., in the Gee Whiz. Came oh so close to getting another deer. Didn't see it all until it was a streak coming across in front of me from left to right. Closest was a couple feet from hitting it. It was the semi-crap light on my Gee Whiz.
This one I would have seen with the lights on the 63. It was even the same road that I hit the last one.
We need a longer hunting season. This is getting nuts around here.
  #84
Old 03-11-2016, 03:00 AM
ycis ycis is offline
figured id update this as im troubleshooting the brake lights and worked on the whole electrical wiring system this week!
got the ebay harness in last night along with 2 new 6" housings fitted with modern h4 halogen bulbs...and its literally brighter than the sun now.
well worth the 25 or so bucks for the harness on ebay...hardest part was disassembling and reassembling the headlight bucket assemblies (and replacing those stupid tiny flat head screws)
1964 Catalina Convertible
  #85
Old 03-11-2016, 04:46 PM
66 Wagon's Avatar
66 Wagon 66 Wagon is offline
I shot a video half a year ago with some evening driving in my wagon with H4 lamps and wiring upgrade.
Too bad I never filmed any night driving with the old wiring and headlamps still on but I can assure my lights are much better now.
Take a look if you want and see if you can spot the small deer crossing the road
Here's the link to the video: "Evening drive in my wagon"
http://forums.maxperformanceinc.com/forums/image.php?type=sigpic&userid=169941&dateline=15132  72224
66 Bonneville 4-door Hardtop - Sold - But it has its own thread here
66 Bonneville Wagon - Sold
63 Grand Prix - Sold
  #86
Old 03-12-2016, 07:14 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
You should try working on an iPad, talk about little screws.
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
  #87
Old 03-29-2016, 08:13 AM
RJ300 RJ300 is offline
I am definitively going to be giving this conversion a go before I do any more night driving in my GP. Standard high beams weren't too bad, but words can even describe how bad the low beam are.
Tossing up whether to buy one of the ready made harnesses or to wire fully myself. Was there a link for the extension harness required for the b body cars?
  #88
Old 03-31-2016, 08:23 AM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
I found these useful
http://www.summitracing.com/parts/rfw-jb57
http://www.summitracing.com/parts/sum-890340
http://www.summitracing.com/parts/rfw-hr58
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
  #89
Old 04-30-2016, 08:46 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
http://www.ebay.com/itm/CERAMIC-H4-H...-/331051630353
This made it so much easier. Red goes to the battery, the relay grounds through the mounting screws.
The black male connector goes on your driver's side original low beam wire and then the four ceramic connectors go to your high beams and low beams. Ground each. You have to fiddle with the connection for the Hella high beams by using the adapter wires in the Hella boxes and then button everything up and go for a drive.
It all ended up being way simpler than I caused it to be with the Ron Francis harness. And I guarantee you that I have all six elements on with high beams on.
I am about to install this exact kit....
I am at a loss as to where to get the adapter harness to convert the H4 connector to the single spade connector for the H1 Bulb.....
I gather the Low Beam is plug and play...... my issue like I said is the High Beam.....
Please Advise from those that have installed this conversion.....
Thank you
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
  #90
Old 05-02-2016, 01:00 PM
X--GASSER's Avatar
X--GASSER X--GASSER is offline
Great info!
  #91
Old 10-21-2016, 11:44 AM
redhawk44's Avatar
redhawk44 redhawk44 is offline
Good info here, subscribing
Let's make welfare as hard to get as Veterans benefits!
  #92
Old 12-19-2016, 05:13 PM
GruntedCatalina GruntedCatalina is offline
you know, I was curious about this because I want to update the old lights too but, I saw someone on here with a special tail light, by light, looks like bulb. it had like a circular glow to the light within the tail light. does anyone know what im talking about here? I thought they were those LED lights in a circular pattern.
