Old 03-07-2024, 10:40 PM
tom s tom s is offline
Default 67 GTO RA pan value
Friend of mine was asking what a factory RA 67 pan is worth?Tom
Old 03-08-2024, 12:44 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
OEM ‘67 pan and air cleaner with correct black lid.
Who knows what these are really worth as they are few.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 03-08-2024, 08:01 PM
geeteeohguy's Avatar
Agreed. If you had one of the scarce '67 Ram Air cars, the high price would be justified if it were missing and you needed it for completion. If you just want it for the bling value, forget it. (at least I would!)
Jeff
Old 03-08-2024, 08:43 PM
242177P's Avatar
242177P 242177P is offline
Hasn't the '67 pan already been reproduced in steel?
Without having a known original to compare it to I'd
be wary of *everything*. Far too many unscrupulous
sellers out there, and weathering items is common.
Old 03-08-2024, 08:49 PM
I told him to join and put it on here.I know he was looking for a lot less.Tom
Old 03-09-2024, 10:35 AM
400 4spd.'s Avatar
I would be interested in seeing pictures of your friend’s pan. Years ago I bought one from a well respected member of this forum that was advertised as NOS. Since then I have seen pictures of original pans that have me doubting if mine is NOS. There was no tag or sticker on mine to verify it was GM.
Old 03-09-2024, 02:17 PM
Jason67's Avatar
Jason67 Jason67 is offline
Originals have the Air Injection tube, repops dont. Alot of the air tubes are cut off, like the one shown in the auction, probably for a non-quadrajet carb.
Jason
The Following User Says Thank You to Jason67 For This Useful Post:
Old 03-12-2024, 09:28 PM
ZeGermanHam's Avatar
Yes, they've been reproduced in steel for years now.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 03-14-2024, 09:30 PM
xsram67 xsram67 is offline
Default Ram air pan
The price is outrageous for a used ram air pan. If it was brand new NOS in perfect condition maybe yes. The tube on the lower side is cut off and it originally would have been about 2" to the 90 degree turn and 2" to the end of the tube with a knurreled end. Also the originals had a rubber plug cover that fit over that tube end. Mine cost $750 in 2008 and original plug was included. Try finding the plug now. Good Luck. I wouldn't have paid any more than $900 for that one. If you want pic of original text Larry 440-823-6252.
