Old 03-27-2015, 10:26 PM
rt400 rt400 is offline
Default 68 GTO glove box
Thia might be a stupid question , but does the glove box go in from the front or back? Seems like either way it is going to get bent up. Thanks in advance.
Old 03-27-2015, 11:56 PM
cuz68's Avatar
cuz68 cuz68 is offline
Front i took the door off.
Cuz68
Old 04-02-2015, 04:19 PM
68pongto's Avatar
68pongto 68pongto is offline
Are you serious? The liner slips right up from the back with no problems. I don't think there would be much left of the liner if you crammed it through the small front opening!
Old 11-03-2023, 10:44 PM
alsalp alsalp is offline
Also does the cardboard lip lay on top of the door hinge or tuck underneath? Are there supposed to be four sheet metal clips for the door?
Old 11-04-2023, 12:14 AM
OG68 OG68 is online now
My RePops box enters from the rear. It has been over twenty years since my car had a glovebox, so it took a bit of trial and error to make it fit right and for the door to line up and close correctly. This is how I did it
Top and sides of box lay behind the dash opening.
The bottom of the box must be bent on the corrugated lines and mounts on top of the dash but under the hinge.
Two clips on the dash mount the door hinge but holes must be punched through the box for the screws to pass through. The inner screws mount the box to the hinge.
Door hinge spring slides between the box and the dash
Two additional clips are required for the upper side screws. They slide onto the box sides
The correct tire pressure decal (not a sticker) can be found here.
https://www.etsy.com/shop/GasTiresan..._id=1432903893
ID:	622766   Click image for larger version
ID:	622767   Click image for larger version
ID:	622768   Click image for larger version
ID:	622770   Click image for larger version
2007 Cadillac SRX
Old 11-04-2023, 01:34 AM
Perfect, thanks.
Are 68 GTO Repops boxes better fitting that REM boxes? I know REM doesn't put clips on the bottom.
Old 11-04-2023, 12:13 PM
So the cardboard needs to be drilled for the outer screws, right?
Old 11-04-2023, 12:28 PM
I just used an awl to poke thru the box after it was mounted. The screws will drive through the hole
2007 Cadillac SRX
Old 11-04-2023, 12:37 PM
Originally Posted by alsalp View Post
Perfect, thanks.
I couldn't say. I can't remember when I bought the box its been so long ago. I just installed it last week
2007 Cadillac SRX
Old 11-04-2023, 01:15 PM
Smile
It's best not rush these things
The Following 2 Users Say Thank You to alsalp For This Useful Post:
Old 11-06-2023, 09:11 PM
Verdoro 68's Avatar
I rarely see where these things end up - the decal looks good! Thanks for the plug
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
