What's your rear end gear? If you're running a 2.56 and are looking for better acceleration, lower gears are a lot cheaper than pulling the engine and starting to throw parts at it.
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
I was given another suggestion, to run E85 with this combo, it is like 106 octane. Does this make sense?
SOLD 72 GTO: http://imgur.com/a/NvOUg My Chevelle project: https://imgur.com/a/v2PHi#0 |
Define "performs like a dog" Is it "only" managing 13 second quarter miles, or does it take 8 seconds to hit 60 mph?
What kind of driving will you be doing? Just around town, or spending hours on the freeway? I haven't heard that about E85, but I'm not a fuel expert.
Try having the carb rebuilt or putting a better carb on it.
I think I will investigate this 106 octane E85 pathway. If I can setup a Q-Jet for E85, I will try that. I might have to replace all the fuel hose in the car but that is no big deal. Lots of E85 gas pumps up here, and way more affordable than 100 octane racing gas.
Could this be the Crane RV cam previous owner chose? http://m.summitracing.com/parts/crn-283901 (260 advertised duration).
Using this cam and 10.1:1 SCR I get 8:43:1 DCR with Wallace racing's dynamic compression ratio calculator. With the Summit 2802 cam (298 advertised duration) I get 7:12:1 DCR. Please correct me if I'm wrong?
1960 Bonneville 2dr HT 389/400ci 363hp 1965 Bonneville 2dr HT 455/501ci stroker 600hp+ |
Without knowing the deck height and actual head CC, it's a crap shoot. Not to mention if it has the rebuilder special pistons or not. If that's the case, the only thing I see that will help is the other heads. You can try a dance around with all the crutches, but I say it will just add to your frustrations while killing time and money. .
I found some guys who have successfully jetted their Quadrajets to run E85. I have a couple Quadrajets to try this with. It might be my winter project.
The E85 should solve the problem with pinging that you're having. It will also allow you to bump the timing to where it should be, most likely vastly improving the power output of the motor. It will also run cooler than on gasoline. Actually, on E85, you ideally want even more compression than what you're running right now, but that's not a major issue. The main issue with E85 is availability. If it's widely sold in your area, then no problem there. You'll use a bit more fuel also, so may need to upgrade fuel delivery (pump, lines, etc).
Sounds like your best first step would be the 2802 cam swap. Even if you had head work done latter you would have a good cam for it. |
The car came in to his shop with what he called a butchered Q-Jet that he fixed up the best he could, and it already had the HEI which he said still needed work when the car left but the owner didn't want anymore work done to it.
If your carb isn't getting full throttle or needs rebuild or just needs to be thrown out. This is where the performance starts lousy carb lousy performance |
As far as carbs go, I put on a new Quick Fuel Hot Rod series 780 cfm vac secondary carb. Out of the box performance was awesome. I think I dialed in idle speed just a touch, idle mixture screws no more than 1/8 from factory settings, and both floats maybe a 1/2 turn.
I was tired of playing with old crap, wondering if the initial jet/rod/etc. setup was right for my combo, and tired of not knowing what level of molestation my carb suffered over the course of 40 years. That cam doesn't look that soft. I ran an 066 cam in a 400, 73 Formula with 3.08 gears. The 066 is a softer cam than the one mentioned above. I didn't have much of a problem getting with it, and running easy 15's.
"...ridge reamer and ring compressor? Do they have tools like that?" Last edited by Squidward; 08-20-2015 at 12:45 AM. |
#38
Used engines with unknown build parameters suck. But your build IMO appears sound according to the numbers. I have a local friend who just put together a 400 build with 62 heads, qjet, 2802 cam, and HEI. It's in a 4 spd 69 'bird, with 3.73's. I can ask him his timing specs. I know he fought some pinging and had to carefully manage his timing. He was running a mix of premium with a little racing gas. IIRC, I think he put in around 32 total. But I know this: He clearly stated he was going to seriously detune before he let his 16 year old drive it, because it was way more car than the lad could handle.
#39
#40
You can dial the timing back to manage it too, but both are crutches. As for E85, from what I understand, there's no way to know if you're getting a consistent mix, it's all over the board. Look at some of the guys over on pro-touring who are running boost and you will see the challenges there. My last 400 was .030 over, TRWs, 62s (or 16s, I forget, but no diff), and was at 9.97 SCR. I ran a 228/236 114 Crane cam similar to the 2802. 3000 stall and 373 gears. I ran 30-32 total, and it was a struggle to keep it from pinging. Get a tank of gas where it's off a little, pings, hot day, pings, engine temps raise a little, pings, 3 people in the car, pings, and once it pings, like noses over, getting it to stop pinging was tough. I went through all the tricks, ran it rich, slowed advance, 160 stat, you name it, I tried it. Constant battle, and made the car no fun to drive. But, when it did run right, like in the fall, cool air, it was a handful. It can be done, but does that sound like fun to you, constantly battling it? .
