Old 05-11-2024, 09:50 PM
1950Mercury 1950Mercury is offline
Default 66 GTO oil filter
Can anyone tell me what Wix oil filter fits a 66 GTO. Book says 51049 but it is too long. I tried a 51258 but thread pitch didn't feel right. I took a Fram PH25 off but I cringe at the thought of installing a new one. I know thread pitch is 13/16 16. And the Fram is 4.050 tall.
Old 05-12-2024, 09:12 AM
The Champ's Avatar
Both the 51049 and the 51258 have 13/16" threads. Wix filter lookup specs the 51049 for a '66 GTO, but the 51258 is a suitable replacement.
Specs for both:
Product Specifications
Part Number: 51049
UPC Number: 765809510494
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Enhanced Cellulose
Height: 5.178(132)*
Outer Diameter Top: 3.66(93)*
Outer Diameter Bottom: Closed:
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 260
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Part Number: 51258
UPC Number: 765809512580
Service: Lube
Type: Full Flow
Height: 4.338(110)*
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 345
I highlighted the differences.
Old 05-13-2024, 02:47 PM
ZeGermanHam's Avatar
I use the Wix 51258 in my '66 with Doug's headers. Great fitment.
1998 BMW 328is (track rat)
Old 05-13-2024, 11:21 PM
I think I now see my issue. It looks like your filter bracket is canted slightly. Mine is straight which puts the filter close to the lower rear A arm bracket.
Old 05-14-2024, 08:53 AM
The Champ's Avatar
The correct filter adapter is the angled one for a '66 GTO. Somewhere along the road, someone either replaced the OE one for some reason or the block came out of another car that came with the straight adapter.
Old 05-14-2024, 12:46 PM
Yes.. It is a 389. Last 4 of block casting is 6769. Thinking block came out of a Catalina or other B body.. I noticed on ZeGermanHams picture the angled adaptor. I'm sure that's my issue.
Old 05-18-2024, 03:57 AM
lust4speed's Avatar
Yes, the 90° filter adapter came on big Pontiacs and the slanted filter adapter on A-bodies.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
Old 05-18-2024, 11:47 AM
Thank you. I received the correct adaptor yesterday, Already on the car and all is good now.
Old 05-21-2024, 11:57 PM
Scott Thelander's Avatar
Thank you for the purchase
Glad all went well
Scott
