Old 08-09-2022, 03:01 PM
lucky1 lucky1 is offline
Default 3/4” fan spacer ?
Anyone aware of a source for a 3/4” cooling fan spacer ?
I currently am using a 1” and am attempting to maximize my cooling system.
Thank you.
Old 08-09-2022, 03:24 PM
ZeGermanHam's Avatar
You can find them on Amazon, or you could likely have your current spacer milled down, but either way I think it's doubtful that a 1/4" reduction will make a difference. Have you considered installing a clutch style fan instead? That would allow you to achieve a correct fan spacing while also freeing up HP, which fixed fans are proven to kill.
1998 BMW 328is (track rat)
Old 08-13-2022, 12:38 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
There are also clutch fans with different length stems.
Skip Fix
Old 08-13-2022, 05:39 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Fan clutch with the correct blade was the biggest improvement I made regarding cooling for my last a-body. I have one now on my GTO that’s hitting the road soon.
