Old 01-31-2023, 01:26 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Default Opinions wanted on gauges
So my 68 GTO is still apart and I want to change over to rally gauges and a Repro tach . The rally’s are actually a 69 Repro . But then I saw these direct fits from Dakota . Spendy at $850 but I’ll 5 in Repro stuff . I’m a geek for stock but, reliable functionality go a long way . What do you guys think ?
When I wore a younger man's clothes
Old 01-31-2023, 08:20 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Looks great and very visible. $850 sounds like a deal for all 3 pods. I like the stock look also, but am having trouble seeing mine in day and night.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 01-31-2023, 09:32 AM
Verdoro 68's Avatar
To me, gauges are such a signature element of a car I can’t imagine swapping them for an aftermarket option.
I don’t understand the complaints about reliability the original set up. It’s a pretty simple set up. I’d be more inclined to buy a used set and have Pete Serio give them a run through. Mine are pretty dang accurate.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 01-31-2023, 10:37 AM
Half-Inch Stud's Avatar
Stock Cluster has resilient function. Senders are simple to optimize. Ground wire from Cluster case to firewall makes the Rally Cluster modern-accurate.
Engine Ground strap from head to firewall completes the circuit.
