Old 09-17-2019, 10:50 AM
70badboy 70badboy is offline
Default body puddy question
On my GTO hood, some of the body puddy that is between the outer sheet metal and inner frame work is missing, Where can I get some to replace it? Thanks Steve
Old 09-17-2019, 11:00 AM
TAKerry TAKerry is offline
I imagine you are talking about the seam sealer. Try a local auto part store. May need to find a mom n pop type, not sure you will find it at auto zone or the likes. I got some clear that was paintable and liked it, but I have seen a lot of it grey. Last bit I got was in standard caulking tube, but it can also come in a can. Might even be able to go to a local body shop and see if they will sell you a tube.
Old 09-17-2019, 06:20 PM
dhutton dhutton is offline
It is not seam sealer as far as I know. You want something that doesn’t harden.
I use 3M NVH adhesive. Requires use of their dispensing gun.
https://www.ebay.com/itm/3M-04274-NV...8810e346c17dbf
Don
Old 09-17-2019, 08:37 PM
Many seam sealers don't harden.
Old 09-17-2019, 09:26 PM
400 4spd.'s Avatar
Don
Don't use seam sealer! It tends to shrink as it cures, and that can make your panel look like it has dents in it where it pulls the panel down. Urethane sealers are the worst. You want a soft expanding foam that won't hold the hood skin down when you park it in the sun. Here is an option that dries much faster than the 3M product.
If you decide to use an expanding soft foam, PM me and I'll give you some tips that might make help.
https://www.jbtools.com/lord-fusor-1...yABEgIPLPD_BwE
The Following User Says Thank You to 400 4spd. For This Useful Post:
Old 09-17-2019, 11:42 PM
MUSLCAH MUSLCAH is offline
Needs a special gun....but good stuff....wear rubbah gloves. Tip : when you use any of these flutter foam products....just make sure you have all your areas ready to go....and once you start ..DONT STOP ....if you stop...the mixture in the tube will start to activate and you won’t be able to squeeze any more product out. You will have to put another mixing tip on.......Dont ask me how I know this......
Old 09-18-2019, 03:52 AM
dataway's Avatar
dataway dataway is offline
Jeez, look at the working time on that stuff .... 15 seconds. That's like weapons grade stuff there
Old 09-18-2019, 06:14 AM
cnc's Avatar
cnc cnc is offline
So this stuff would be great for the under hood bracing that always separates from the hood especially TA hoods
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-18-2019, 01:02 PM
HWYSTR455's Avatar
Local auto body supply places carry it, or similar products.
Old 02-20-2020, 10:03 AM
a421cat a421cat is offline
I worked for Chrysler for over 20 years and what they used on the hood line was called anti flutter. 2 separate drums and the product was mixed in the lines before it got to the dispense nozzle. I think it was a 2 part epoxy. Most important is that it does not shrink as it cures or you will get whats called suck down. Your hood will have a depression above where the epoxy was applied.
Old 02-20-2020, 11:55 AM
dataway's Avatar
What about SEM 39977 instead of the SEM 39357 ?
Old 02-20-2020, 09:45 PM
I can’t remember numbers.....but what does the cartridge say....vs the one I told you ?
Old 02-21-2020, 03:44 AM
dataway's Avatar
One says flexible Urethane foam, the other says Panel Vibration Foam ... the Flexible Urethane (39357) dries way quicker.
Old 02-21-2020, 10:38 AM
78w72 78w72 is offline
i just used 3M wind shield sealant in a caulk tube on my 2nd gen hood where the factory stuff came loose. its black & looks just like the original stuff & has held up for 10 years now with no signs of letting go or causing any shrinkage/dents etc. good strong stuff & about $10/tube.
Old 02-21-2020, 11:23 PM
They keep coming out with new stuff all the time.....looks like either one will work...just stay away from the stuff that dries hard. When I put door skins on a door...there are structures I have to transfer from the damaged skin.....and all those metal reinforcements alway have flutter foam holding them to the inside of the skin and crash bar.
Old 02-25-2020, 09:04 PM
Body Puddy.....? Or Putty ?......eny vs any .... or up here it’s Smaht .....not Smart..
Old 02-26-2020, 08:42 AM
Murf Murf is offline
It’s Puddy!
https://images.app.goo.gl/GU6hjNFogRnCg45u7
Sent from my iPhone using Tapatalk Pro
The Following User Says Thank You to Murf For This Useful Post:
