WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 2004-06 GTO Owners > 04-06 Engine Tech
04-06 Engine Tech LS engine tech center. Get the most out of your car here.
Old 07-09-2007, 04:35 PM
Pontiac Slim's Avatar
Pontiac Slim Pontiac Slim is offline
Default Blew engine in 06 GTO ?
Hey..
Son blew the engine in his 06 GTO.. Pontiac service dept says he was doing 60mph in 4th gear, car has less then 3000 miles and is a 6 speed.
Heard a rumor that the 06/6 speeds were have'n issues. Anyone hear anything about that?
Pontiac Slim
Old 07-09-2007, 06:30 PM
Verdoro 68's Avatar
LS engines are pretty tough. I haven't heard anything about the engines blowing. I've got a few friends running major boost and huge nitrous shots on stock bottom ends with no problems. If he was revving it too high shouldn't the rev limited have caught it? I bounced off my limited a couple times while doing a burnout a the track the other day.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 07-10-2007, 02:14 AM
Jeff R's Avatar
Jeff R Jeff R is offline
Like Ken said, these engines are tough. 60mph in 4th gear is only about 2700rpms. Hell, I wind mine up to 60 in 2nd gear fairly often, and that's still just shy of hitting the rev limiter. The only somewhat-common issue I'm aware of with LS2s is that some consume oil much quicker than others. Maybe your son's car had this problem and it was running itself dry. Whatever the case he should get a new motor under warranty.
Old 07-10-2007, 08:41 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Originally Posted by Pontiac Slim
Hey..
Pontiac Slim
False. No rumor. Something happened and if one dealer doesn't help, another should. Or find out exactly what happened. How old is your boy?
Old 07-12-2007, 08:24 PM
dragula81's Avatar
dragula81 dragula81 is offline
"Rumor" was definitely NOT true. There are 100's of guys with Maggies, twin turbos, Nitrous, Prochargers on stock bottom-end LS2's that have not had any trouble.
BTW, when racing I shift out of SECOND gear at about 67 mph. Fourth at 60 is a non-issue.
Drag
www.dixiemusclecars.com
The Southeast's only online Community dedicated to the American Muscle Car!
2006 PBM GTO LS2
1995 Arctic White Trans Am LT1
1981 Trans Am Daytona Pace Car
1969 Gold Poly Firebird w/400
Old 07-13-2007, 07:31 PM
Hey..
Ya.. sort-a figured twas a rumor as didn't add up to me... Son is 27 had a new BMW before the GTO.. Hadn't run the car hard as was try'n to get some miles on it. He turned the matter over to his lawyer...
Thanks for imput..
Pontiac Slim
Old 07-19-2007, 03:33 PM
disc0monkey's Avatar
disc0monkey disc0monkey is offline
the dealer should be able to tell if it was a mis-shift/over reving. with 3k miles the shifter would have a lot resistance when trying to go into 1st gear at that speed. that is the only gear that would hurt the motor.
Featured Vendors
Advertising Info
