#201
Took today and yesterday off work so I could focus on the GTO. I spent yesterday priming the underside of the body and firewall. It was my first time ever using an HVLP spray gun and 2-part epoxy. I used PPG DP90, and it came out pretty good I think!
Today I will be doing the seam sealing, then spraying the underside with 3M undercoating. Not original, but I want the protection from rock chips and also the acoustic benefit. If things go well today, I will hopefully be putting the body back on the frame this weekend!
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#202
That looks Great. Are you leaving the firewall in primer? Or are you going to top coat?
Thanks for the update on your progress. |
#203
To my understanding (others will correct me if I'm wrong), the firewall is supposed to be more flat than the fender housings. So when I tackle those, I'll probably leave them with the DP90 primer as the top coat, since it's slightly more glossy than the Rust Encapsulator that will be on the firewall. I'm must glad I didn't botch laying down the primer. Having never used an HVLP gun before, I was pretty nervous about it beforehand. Now with my positive experience priming the underside, I'll probably tackle the job of priming the inside of the body, too. Definitely going to leave the body exterior to the pros, though. I just wish DP90 wasn't so darn expensive...
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 09-04-2020 at 11:52 AM. |
#204
As far as I know you are right about the firewall being flatter than the other under hood pieces. I've been planning on flattening a single-stage black myself, but might look at the product you mentioned. I'm going to be shooting red oxide primer so I'll have no choice but to top-coat.
Check out SPI epoxy...great reputation and far less money than DP90. |
#205
I'll be sure to post some photos once I've top coated the firewall so you can get a sense of what it looks like when done.
#206
Here is what the Eastwood rust encapsulator rattle can looks like. It's just a tad less glossy than the DP90 primer. It's also heat resistant up to 400F, so it should be good for under hood use.
#207
That looks pretty good. Thanks for the pictures.
#208
Ze..why no seam sealer above and down the sides of the body mount bulkheads? My 67 Tempest had it in that location. Your car is looking great.
#209
It may be hard to see in the photos, but there is seam sealer on the sides of the body mount bulkheads. As for the top edges, I looked at my photos taken during disassembly and noted that there was zero seam sealer from the factory in that location on my car. I just replicated how it was before. I've heard that there was some variation in how seam sealer was applied at the factory, so maybe that explains why our cars are different. Which plant did you're Tempest come from?
#210
Ze... I've owned the car since 1980 and I've never bothered to decode the Vin. I guess I should really do that now, seeing as I'm restoring the car. I'll look into it and let you know..... It seems to make sense that there would be seam sealer above the bulk heads to prevent water from running down into the mount area and getting trapped.
#211
Fantastic work! I haven't followed this thread the past couple of months but I like what I'm seeing. With yours being a Pontiac plant car, you may want to study some firewall pictures and see how the body color extended further downward on the firewall than other plants. And you're on track with the firewall needing to be flatter than underneath the car. DP90 would not give you the shade and gloss you are after. Also, the firewall was shot after the body color if that helps. PM if you like.
#212
Appreciate the info on firewall painting, too.
#213
Ze...Very interesting, thanks for sharing. I always find it interesting when the differences between the different assembly plants are pointed out.
#214
Sunday update: I'm happy to report that after about ten months of work, the body has once again been "married" to the frame. I suppose it means they have renewed their vows... It's a major mental milestone for me, and it will surely stoke the fire within to continue pushing on the project.
#215
Very cool...big step, congrats
#216
Thank you! Big step, indeed.
I will say, I'm not terribly impressed by the body mount kit from OPGI. The supplied hardware is very low-grade, and the none of the bushings fit the two holes in the middle of the frame (these holes are smaller than the rest). It was easy enough to trim the bushings down to fit, but still. I'm surprised by this snag, since the body mount kit had been highly reviewed on OGPI's website. Maybe there's some selective "filtering" going on with the reviews they post.
#217
That ppg DP 40 sure smells awful
#218
Yeah, fortunately I didn't smell much of the DP90 except for when I bumped or adjusted my respirator. Paint is nasty stuff.
#219
Ze.. I had the same issue with the same body mount location. My body mount kit came from Ames...I had to modify them too.
#220
That's interesting to hear. In that case, I wonder if the body mount kits that are available are just generic A-body kits and perhaps Pontiac frames are different in that location compared to Chevy, Buick, Olds frames.
